1 |
.\" RCSid "$Id" |
2 |
.TH RHOLO 1 6/10/98 RADIANCE |
3 |
.SH NAME |
4 |
glrad - render a RADIANCE scene using OpenGL |
5 |
.SH SYNOPSIS |
6 |
.B glrad |
7 |
8 |
.B \-w |
9 |
10 |
.B \-b |
11 |
12 |
.B \-s |
13 |
14 |
.B \-S |
15 |
16 |
.B "\-v view" |
17 |
18 |
.B rfile |
19 |
20 |
.B "VAR\=value .." |
21 |
22 |
.SH DESCRIPTION |
23 |
.I Glrad |
24 |
renders a Radiance scene description in OpenGL. |
25 |
Its syntax and behavior is similar to |
26 |
.I rad(1) |
27 |
with the |
28 |
.I \-o |
29 |
option, where the output device is assumed to be an X11 server |
30 |
with GLX extensions. |
31 |
.PP |
32 |
The |
33 |
.I \-w |
34 |
option turns off warnings. |
35 |
The |
36 |
.I \-s |
37 |
option tells |
38 |
.I glrad |
39 |
to run |
40 |
.I rad |
41 |
silently, not echoing |
42 |
.I oconv(1) |
43 |
command. |
44 |
The |
45 |
.I \-b |
46 |
option turns off back face visibility (i.e., enables back face culling). |
47 |
This is equivalent to the |
48 |
.I \-bv |
49 |
option of |
50 |
.I rpict(1) |
51 |
and |
52 |
.I rview(1). |
53 |
The |
54 |
.I \-S |
55 |
option turns on full-screen stereo for displays that support it. |
56 |
(Be sure to run |
57 |
.I /usr/gfx/setmon(1) |
58 |
or its equivalent to set STR_TOP or STR_BOT, first.)\0 |
59 |
The |
60 |
.I \-v |
61 |
option may be used to specify a starting view, either by symbolic name |
62 |
as entered in the |
63 |
.I view |
64 |
assignments in |
65 |
.I rfile, |
66 |
or by a complete view specification, enclosed in quotes. |
67 |
If no view is specified, then the first standard view from |
68 |
.I rfile |
69 |
is used to start. |
70 |
.PP |
71 |
Variables permitted in |
72 |
.I rfile |
73 |
are described in the |
74 |
.I rad |
75 |
manual page. |
76 |
Additional or overriding assignments may be given on the command line |
77 |
following |
78 |
.I rfile. |
79 |
.PP |
80 |
The view is controlled via the mouse and simple one-character commands, |
81 |
listed below: |
82 |
.TP 10n |
83 |
.BR "(mouse)" |
84 |
Modify the current view. |
85 |
The mouse is used to control the current view in the following ways: |
86 |
.sp |
87 |
.nf |
88 |
CONTROL MOUSE ACTION |
89 |
(none) left Move forward towards cursor position |
90 |
(none) right Move backward away from cursor position |
91 |
(none) middle Rotate in place (usually safe) |
92 |
shift left Orbit left around cursor position |
93 |
shift right Orbit right around cursor position |
94 |
shift middle Orbit skyward |
95 |
cntl middle Orbit earthward |
96 |
.fi |
97 |
.sp |
98 |
For all movements but rotating in place, the cursor must be placed over some |
99 |
bit of visible geometry, otherwise the program has no reference point from |
100 |
which to work. |
101 |
It is best to just experiment with these controls until you learn to fly |
102 |
safely in your model. |
103 |
And if you run into trouble, the 'l' command is very useful. |
104 |
(See below.)\0 |
105 |
.TP |
106 |
.BR '+' |
107 |
Zoom in on the current cursor position. |
108 |
(Beware of repeating keys that go faster than the display updates.) |
109 |
.TP |
110 |
.BR '-' |
111 |
Zoom out from the current cursor position. |
112 |
.TP |
113 |
.BR 'l' |
114 |
Return to the last saved view. |
115 |
Each time a new command changes the current view, the last view |
116 |
is saved, and may be recalled with this command. |
117 |
Multiple uses of the same command (e.g., rotation, zoom) will |
118 |
save only the view before the first such command. |
119 |
This way, it is easy to get back to where you were before a sequence |
120 |
of view changes. |
121 |
.TP |
122 |
.BR 'h' |
123 |
Fix the head height. |
124 |
All mouse-controlled view motions will be adjusted so that the head height |
125 |
does not change (where vertical is determined by the current |
126 |
view up vector). |
127 |
.TP |
128 |
.BR 'H' |
129 |
Release the head height, allowing it to change again during mouse-controlled |
130 |
movements. |
131 |
.TP |
132 |
.BR 'v' |
133 |
Print the current view parameters to the standard output. |
134 |
This is useful for finding out where you are, or for saving specific |
135 |
views in a keyframe file for animations or returning to later. |
136 |
.TP |
137 |
.BR 'V' |
138 |
Append the current view to the original |
139 |
.I rfile. |
140 |
This view will be unnamed, but can be referred to by number or the |
141 |
user may add a name later with a text editor. |
142 |
The current view number becomes the last standard view. |
143 |
(See the 'n' and 'p' commands, below.) |
144 |
.TP |
145 |
.BR 'n' |
146 |
Go to the next standard view stored in |
147 |
.I rfile. |
148 |
If the last view is currently displayed, then cycle to the first one. |
149 |
.TP |
150 |
.BR 'p' |
151 |
Go to the previous standard view stored in |
152 |
.I rfile. |
153 |
If the first view is currently displayed, then cycle to the last one. |
154 |
.TP |
155 |
.BR 'q' |
156 |
Quit |
157 |
.I glrad. |
158 |
This is the normal way to exit the program. |
159 |
.SH AUTHOR |
160 |
Greg Ward Larson |
161 |
.SH BUGS |
162 |
It would be nice if |
163 |
.I glrad |
164 |
set the appropriate video format for stereo viewing automatically, |
165 |
but the process is different on different systems and there is no |
166 |
single, sure-fire way to do it for all systems. |
167 |
On systems that do not support stereo extensions, the program |
168 |
may be compiled with the -DNOSTEREO option, which will avoid |
169 |
undefined symbol errors. |
170 |
.SH "SEE ALSO" |
171 |
chmod(1), getinfo(1), ls(1), objview(1), oconv(1), ps(1), rad(1), |
172 |
ranimate(1), rhcopy(1), rholo(1), rpict(1), rtrace(1), rview(1), setmon(1) |
