root/radiance/ray/doc/man/man1/getinfo.1
Revision: 1.11
Committed: Mon Mar 21 17:12:49 2022 UTC (3 years, 2 months ago) by greg
CVS Tags: rad5R4, HEAD
docs(getinfo): Slight clarification
1 .\" RCSid "$Id: getinfo.1,v 1.10 2022/03/21 00:21:13 greg Exp $"
2 .TH GETINFO 1 1/15/99 RADIANCE
3 .SH NAME
4 getinfo - get header information from a RADIANCE file
5 .SH SYNOPSIS
6 .B getinfo
7 [
8 .B -d
9 |
10 .B +d
11 ][
12 .B "file .."
13 ]
14 .br
15 .B getinfo
16 [
17 .B -d
18 ]
19 -
20 .br
21 .B getinfo
22 {
23 .B -a
24 |
25 .B -r
26 }
27 .B "info_line1 .."
28 .br
29 .B getinfo
30 [
31 .B -d
32 |
33 .B +d
34 ]
35 .B -c
36 .B "command .."
37 .SH DESCRIPTION
38 .I Getinfo
39 reads the header of each RADIANCE
40 .I file
41 and writes it to the standard output.
42 Octree and picture files are in a binary format, which makes
43 it difficult to determine their content.
44 Therefore, a few lines of text are placed at the beginning
45 of each file by the RADIANCE program that creates it.
46 The end of the header information and the start of the
47 data is indicated by an empty line.
48 The
49 .I \-d
50 option can be used to print the dimensions of an octree or
51 picture file instead.
52 For an octree,
53 .I "getinfo \-d"
54 prints the bounding cube (xmin ymin zmin size).
55 For a picture,
56 .I "getinfo \-d"
57 prints the y and x resolution (\-Y yres +X xres).
58 The
59 .I \+d
60 option prints the header followed by a newline and the dimensions.
61 If no
62 .I file
63 is given, the standard input is read.
64 .PP
65 The second form of
66 .I getinfo
67 with a hyphen simply removes the header
68 and copies the body of the file from the standard
69 input to the standard output.
70 If the
71 .I \-d
72 option is given, then the resolution string will be elided as well.
73 .PP
74 The third form of
75 .I "getinfo \-a"
76 adds one or more header lines to the standard input.
77 These lines are given as arguments to
78 .I getinfo,
79 and must be quoted if they contain spaces.
80 The alternative form with
81 .I \-r
82 replaces any previous occurances of the settings in the given
83 line(s) with nothing if there is only one word, or with
84 the whole line if quoted and containing interior white space or
85 an equals sign ('=').
86 Any leading white space matches any leading number of spaces and
87 tabs in the input header.
88 .PP
89 The fourth form of
90 .I "getinfo \-c"
91 is followed by a command and its arguments, which is executed
92 on the data segment of the standard input.
93 The header is passed along, with the addition of the command
94 at the end.
95 This is roughly equivalent to the following sequence, but does not
96 require the input to be in a file:
97 .IP "" .2i
98 ( getinfo < input ; getinfo - < input | command .. )
99 .PP
100 If the
101 .I \+d
102 option is given with
103 .I \-c,
104 then the resolution string will be copied before the command is called.
105 If the
106 .I \-d
107 option is given, then the resolution string is read in but not copied.
108 .SH EXAMPLES
109 To print the header information from scene1.oct and scene2.hdr:
110 .IP "" .2i
111 getinfo scene1.oct scene2.hdr
112 .PP
113 To print the dimensions of a set of pictures:
114 .IP "" .2i
115 getinfo -d *.hdr
116 .PP
117 To add two header lines modifying the view
118 and exposure calibration of a picture:
119 .IP "" .2i
120 getinfo -a "VIEW= -vta -vh 180 -vv 180" "EXPOSURE=1.5" < orig.hdr > modified.hdr
121 .PP
122 To remove any indented lines containing "EXPOSURE=" and replace any
123 left-justified "EXPOSURE=" lines with a single value of 16:
124 .IP "" .2i
125 getinfo -r " EXPOSURE=" "EXPOSURE=16" < orig.hdr > fixed.hdr
126 .PP
127 To raise floating-point matrix elements to a power of 2.7:
128 .IP "" .2i
129 getinfo -c rcalc -if -of -e '$1=$1^2.7' < input.fmx > output.fmx
130 .SH AUTHOR
131 Greg Ward
132 .SH "SEE ALSO"
133 oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rsplit(1), rtrace(1), rvu(1)
