--- ray/doc/man/man1/getinfo.1 2003/03/11 19:20:21 1.1 +++ ray/doc/man/man1/getinfo.1 2022/03/21 00:21:13 1.10 @@ -1,4 +1,4 @@ -.\" RCSid "$Id" +.\" RCSid "$Id: getinfo.1,v 1.10 2022/03/21 00:21:13 greg Exp $" .TH GETINFO 1 1/15/99 RADIANCE .SH NAME getinfo - get header information from a RADIANCE file @@ -6,12 +6,34 @@ getinfo - get header information from a RADIANCE file .B getinfo [ .B -d +| +.B +d ][ .B "file .." ] .br .B getinfo +[ +.B -d +] - +.br +.B getinfo +{ +.B -a +| +.B -r +} +.B "info_line1 .." +.br +.B getinfo +[ +.B -d +| +.B +d +] +.B -c +.B "command .." .SH DESCRIPTION .I Getinfo reads the header of each RADIANCE @@ -32,19 +54,78 @@ For an octree, prints the bounding cube (xmin ymin zmin size). For a picture, .I "getinfo \-d" -prints the y and x resolution (-Y yres +X xres). +prints the y and x resolution (\-Y yres +X xres). +The +.I \+d +option prints the header followed by a newline and the dimensions. If no .I file is given, the standard input is read. .PP -The second form of getinfo with a hyphen simply removes the header +The second form of +.I getinfo +with a hyphen simply removes the header and copies the body of the file from the standard input to the standard output. -.SH EXAMPLE -To print the header information from scene1.oct and scene2.pic: +If the +.I \-d +option is given, then the resolution string will be elided as well. +.PP +The third form of +.I "getinfo \-a" +adds one or more header lines to the standard input. +These lines are given as arguments to +.I getinfo, +and must be quoted if they contain spaces. +The alternative form with +.I \-r +replaces any previous occurances of the settings in the given +line(s) with nothing if there is only one word, or with +the whole line if quoted and containing interior white space or +an equals sign ('='). +.PP +The fourth form of +.I "getinfo \-c" +is followed by a command and its arguments, which is executed +on the data segment of the standard input. +The header is passed along, with the addition of the command +at the end. +This is roughly equivalent to the following sequence, but does not +require the input to be in a file: .IP "" .2i -getinfo scene1.oct scene2.pic +( getinfo < input ; getinfo - < input | command .. ) +.PP +If the +.I \+d +option is given with +.I \-c, +then the resolution string will be copied before the command is called. +If the +.I \-d +option is given, then the resolution string is read in but not copied. +.SH EXAMPLES +To print the header information from scene1.oct and scene2.hdr: +.IP "" .2i +getinfo scene1.oct scene2.hdr +.PP +To print the dimensions of a set of pictures: +.IP "" .2i +getinfo -d *.hdr +.PP +To add two header lines modifying the view +and exposure calibration of a picture: +.IP "" .2i +getinfo -a "VIEW= -vta -vh 180 -vv 180" "EXPOSURE=1.5" < orig.hdr > modified.hdr +.PP +To remove any indented lines containing "EXPOSURE=" and replace any +left-justified "EXPOSURE=" lines with a single value of 16: +.IP "" .2i +getinfo -r " EXPOSURE=" "EXPOSURE=16" < orig.hdr > fixed.hdr +.PP +To raise floating-point matrix elements to a power of 2.7: +.IP "" .2i +getinfo -c rcalc -if -of -e '$1=$1^2.7' < input.fmx > output.fmx .SH AUTHOR Greg Ward .SH "SEE ALSO" -oconv(1), pfilt(1), rhinfo(1), rpict(1), rview(1) +oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rsplit(1), rtrace(1), rvu(1)
