root/Development/ray/doc/man/man1/getinfo.1
Revision: 1.6
Committed: Mon Jul 28 17:25:03 2014 UTC (11 years, 3 months ago) by greg
CVS Tags: rad5R0, rad4R2P2, rad4R2P1, rad4R2
Changes since 1.5: +20 -3 lines
1 .\" RCSid "$Id: getinfo.1,v 1.5 2008/11/10 19:08:17 greg Exp $"
2 .TH GETINFO 1 1/15/99 RADIANCE
3 .SH NAME
4 getinfo - get header information from a RADIANCE file
5 .SH SYNOPSIS
6 .B getinfo
7 [
8 .B -d
9 ][
10 .B "file .."
11 ]
12 .br
13 .B getinfo
14 -
15 .br
16 .B getinfo
17 .B -c
18 .B "command .."
19 .SH DESCRIPTION
20 .I Getinfo
21 reads the header of each RADIANCE
22 .I file
23 and writes it to the standard output.
24 Octree and picture files are in a binary format, which makes
25 it difficult to determine their content.
26 Therefore, a few lines of text are placed at the beginning
27 of each file by the RADIANCE program that creates it.
28 The end of the header information and the start of the
29 data is indicated by an empty line.
30 The
31 .I \-d
32 option can be used to print the dimensions of an octree or
33 picture file instead.
34 For an octree,
35 .I "getinfo \-d"
36 prints the bounding cube (xmin ymin zmin size).
37 For a picture,
38 .I "getinfo \-d"
39 prints the y and x resolution (\-Y yres +X xres).
40 If no
41 .I file
42 is given, the standard input is read.
43 .PP
44 The second form of
45 .I getinfo
46 with a hyphen simply removes the header
47 and copies the body of the file from the standard
48 input to the standard output.
49 .PP
50 The third form of
51 .I "getinfo \-c"
52 is followed by a command and its arguments, which is executed
53 on the data segment of the standard input.
54 The header is passed along, with the addition of the command
55 at the end.
56 This is roughly equivalent to the following sequence, but does not
57 require the input to be in a file:
58 .IP "" .2i
59 ( getinfo < input ; getinfo - < input | command .. )
60 .SH EXAMPLE
61 To print the header information from scene1.oct and scene2.hdr:
62 .IP "" .2i
63 getinfo scene1.oct scene2.hdr
64 .SH AUTHOR
65 Greg Ward
66 .SH "SEE ALSO"
67 oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rvu(1)
