1 |
.\" RCSid "$Id: getinfo.1,v 1.7 2016/08/30 06:10:12 greg Exp $" |
2 |
.TH GETINFO 1 1/15/99 RADIANCE |
3 |
.SH NAME |
4 |
getinfo - get header information from a RADIANCE file |
5 |
.SH SYNOPSIS |
6 |
.B getinfo |
7 |
8 |
.B -d |
9 |
10 |
.B "file .." |
11 |
12 |
.br |
13 |
.B getinfo |
14 |
15 |
.B -d |
16 |
17 |
18 |
.br |
19 |
.B getinfo |
20 |
.B -a |
21 |
.B "info_line1 .." |
22 |
.br |
23 |
.B getinfo |
24 |
25 |
.B -d |
26 |
27 |
.B -c |
28 |
.B "command .." |
29 |
.SH DESCRIPTION |
30 |
.I Getinfo |
31 |
reads the header of each RADIANCE |
32 |
.I file |
33 |
and writes it to the standard output. |
34 |
Octree and picture files are in a binary format, which makes |
35 |
it difficult to determine their content. |
36 |
Therefore, a few lines of text are placed at the beginning |
37 |
of each file by the RADIANCE program that creates it. |
38 |
The end of the header information and the start of the |
39 |
data is indicated by an empty line. |
40 |
The |
41 |
.I \-d |
42 |
option can be used to print the dimensions of an octree or |
43 |
picture file instead. |
44 |
For an octree, |
45 |
.I "getinfo \-d" |
46 |
prints the bounding cube (xmin ymin zmin size). |
47 |
For a picture, |
48 |
.I "getinfo \-d" |
49 |
prints the y and x resolution (\-Y yres +X xres). |
50 |
If no |
51 |
.I file |
52 |
is given, the standard input is read. |
53 |
.PP |
54 |
The second form of |
55 |
.I getinfo |
56 |
with a hyphen simply removes the header |
57 |
and copies the body of the file from the standard |
58 |
input to the standard output. |
59 |
If the |
60 |
.I \-d |
61 |
option is included, then the resolution string will be elided as well. |
62 |
.PP |
63 |
The third form of |
64 |
.I "getinfo \-a" |
65 |
adds one or more header lines to the standard input. |
66 |
These lines are given as arguments to |
67 |
.I getinfo, |
68 |
and must be quoted if they contain spaces. |
69 |
.PP |
70 |
The fourth form of |
71 |
.I "getinfo \-c" |
72 |
is followed by a command and its arguments, which is executed |
73 |
on the data segment of the standard input. |
74 |
The header is passed along, with the addition of the command |
75 |
at the end. |
76 |
This is roughly equivalent to the following sequence, but does not |
77 |
require the input to be in a file: |
78 |
.IP "" .2i |
79 |
( getinfo < input ; getinfo - < input | command .. ) |
80 |
.PP |
81 |
If the |
82 |
.I \-d |
83 |
option is included, then the resolution string will be copied |
84 |
before the command is called. |
85 |
.SH EXAMPLE |
86 |
To print the header information from scene1.oct and scene2.hdr: |
87 |
.IP "" .2i |
88 |
getinfo scene1.oct scene2.hdr |
89 |
.SH AUTHOR |
90 |
Greg Ward |
91 |
.SH "SEE ALSO" |
92 |
oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rsplit(1), rtrace(1), rvu(1) |
