| 1 |
.\" RCSid "$Id: getinfo.1,v 1.10 2022/03/21 00:21:13 greg Exp $" |
| 2 |
.TH GETINFO 1 1/15/99 RADIANCE |
| 3 |
.SH NAME |
| 4 |
getinfo - get header information from a RADIANCE file |
| 5 |
.SH SYNOPSIS |
| 6 |
.B getinfo |
| 7 |
| 8 |
.B -d |
| 9 |
| 10 |
.B +d |
| 11 |
| 12 |
.B "file .." |
| 13 |
| 14 |
.br |
| 15 |
.B getinfo |
| 16 |
| 17 |
.B -d |
| 18 |
| 19 |
| 20 |
.br |
| 21 |
.B getinfo |
| 22 |
| 23 |
.B -a |
| 24 |
| 25 |
.B -r |
| 26 |
| 27 |
.B "info_line1 .." |
| 28 |
.br |
| 29 |
.B getinfo |
| 30 |
| 31 |
.B -d |
| 32 |
| 33 |
.B +d |
| 34 |
| 35 |
.B -c |
| 36 |
.B "command .." |
| 37 |
.SH DESCRIPTION |
| 38 |
.I Getinfo |
| 39 |
reads the header of each RADIANCE |
| 40 |
.I file |
| 41 |
and writes it to the standard output. |
| 42 |
Octree and picture files are in a binary format, which makes |
| 43 |
it difficult to determine their content. |
| 44 |
Therefore, a few lines of text are placed at the beginning |
| 45 |
of each file by the RADIANCE program that creates it. |
| 46 |
The end of the header information and the start of the |
| 47 |
data is indicated by an empty line. |
| 48 |
The |
| 49 |
.I \-d |
| 50 |
option can be used to print the dimensions of an octree or |
| 51 |
picture file instead. |
| 52 |
For an octree, |
| 53 |
.I "getinfo \-d" |
| 54 |
prints the bounding cube (xmin ymin zmin size). |
| 55 |
For a picture, |
| 56 |
.I "getinfo \-d" |
| 57 |
prints the y and x resolution (\-Y yres +X xres). |
| 58 |
The |
| 59 |
.I \+d |
| 60 |
option prints the header followed by a newline and the dimensions. |
| 61 |
If no |
| 62 |
.I file |
| 63 |
is given, the standard input is read. |
| 64 |
.PP |
| 65 |
The second form of |
| 66 |
.I getinfo |
| 67 |
with a hyphen simply removes the header |
| 68 |
and copies the body of the file from the standard |
| 69 |
input to the standard output. |
| 70 |
If the |
| 71 |
.I \-d |
| 72 |
option is given, then the resolution string will be elided as well. |
| 73 |
.PP |
| 74 |
The third form of |
| 75 |
.I "getinfo \-a" |
| 76 |
adds one or more header lines to the standard input. |
| 77 |
These lines are given as arguments to |
| 78 |
.I getinfo, |
| 79 |
and must be quoted if they contain spaces. |
| 80 |
The alternative form with |
| 81 |
.I \-r |
| 82 |
replaces any previous occurances of the settings in the given |
| 83 |
line(s) with nothing if there is only one word, or with |
| 84 |
the whole line if quoted and containing interior white space or |
| 85 |
an equals sign ('='). |
| 86 |
Any leading white space matches any leading number of spaces and |
| 87 |
tabs in the input header. |
| 88 |
.PP |
| 89 |
The fourth form of |
| 90 |
.I "getinfo \-c" |
| 91 |
is followed by a command and its arguments, which is executed |
| 92 |
on the data segment of the standard input. |
| 93 |
The header is passed along, with the addition of the command |
| 94 |
at the end. |
| 95 |
This is roughly equivalent to the following sequence, but does not |
| 96 |
require the input to be in a file: |
| 97 |
.IP "" .2i |
| 98 |
( getinfo < input ; getinfo - < input | command .. ) |
| 99 |
.PP |
| 100 |
If the |
| 101 |
.I \+d |
| 102 |
option is given with |
| 103 |
.I \-c, |
| 104 |
then the resolution string will be copied before the command is called. |
| 105 |
If the |
| 106 |
.I \-d |
| 107 |
option is given, then the resolution string is read in but not copied. |
| 108 |
.SH EXAMPLES |
| 109 |
To print the header information from scene1.oct and scene2.hdr: |
| 110 |
.IP "" .2i |
| 111 |
getinfo scene1.oct scene2.hdr |
| 112 |
.PP |
| 113 |
To print the dimensions of a set of pictures: |
| 114 |
.IP "" .2i |
| 115 |
getinfo -d *.hdr |
| 116 |
.PP |
| 117 |
To add two header lines modifying the view |
| 118 |
and exposure calibration of a picture: |
| 119 |
.IP "" .2i |
| 120 |
getinfo -a "VIEW= -vta -vh 180 -vv 180" "EXPOSURE=1.5" < orig.hdr > modified.hdr |
| 121 |
.PP |
| 122 |
To remove any indented lines containing "EXPOSURE=" and replace any |
| 123 |
left-justified "EXPOSURE=" lines with a single value of 16: |
| 124 |
.IP "" .2i |
| 125 |
getinfo -r " EXPOSURE=" "EXPOSURE=16" < orig.hdr > fixed.hdr |
| 126 |
.PP |
| 127 |
To raise floating-point matrix elements to a power of 2.7: |
| 128 |
.IP "" .2i |
| 129 |
getinfo -c rcalc -if -of -e '$1=$1^2.7' < input.fmx > output.fmx |
| 130 |
.SH AUTHOR |
| 131 |
Greg Ward |
| 132 |
.SH "SEE ALSO" |
| 133 |
oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rsplit(1), rtrace(1), rvu(1) |
