1 |
.\" RCSid "$Id: getinfo.1,v 1.10 2022/03/21 00:21:13 greg Exp $" |
2 |
.TH GETINFO 1 1/15/99 RADIANCE |
3 |
.SH NAME |
4 |
getinfo - get header information from a RADIANCE file |
5 |
.SH SYNOPSIS |
6 |
.B getinfo |
7 |
8 |
.B -d |
9 |
10 |
.B +d |
11 |
12 |
.B "file .." |
13 |
14 |
.br |
15 |
.B getinfo |
16 |
17 |
.B -d |
18 |
19 |
20 |
.br |
21 |
.B getinfo |
22 |
23 |
.B -a |
24 |
25 |
.B -r |
26 |
27 |
.B "info_line1 .." |
28 |
.br |
29 |
.B getinfo |
30 |
31 |
.B -d |
32 |
33 |
.B +d |
34 |
35 |
.B -c |
36 |
.B "command .." |
37 |
.SH DESCRIPTION |
38 |
.I Getinfo |
39 |
reads the header of each RADIANCE |
40 |
.I file |
41 |
and writes it to the standard output. |
42 |
Octree and picture files are in a binary format, which makes |
43 |
it difficult to determine their content. |
44 |
Therefore, a few lines of text are placed at the beginning |
45 |
of each file by the RADIANCE program that creates it. |
46 |
The end of the header information and the start of the |
47 |
data is indicated by an empty line. |
48 |
The |
49 |
.I \-d |
50 |
option can be used to print the dimensions of an octree or |
51 |
picture file instead. |
52 |
For an octree, |
53 |
.I "getinfo \-d" |
54 |
prints the bounding cube (xmin ymin zmin size). |
55 |
For a picture, |
56 |
.I "getinfo \-d" |
57 |
prints the y and x resolution (\-Y yres +X xres). |
58 |
The |
59 |
.I \+d |
60 |
option prints the header followed by a newline and the dimensions. |
61 |
If no |
62 |
.I file |
63 |
is given, the standard input is read. |
64 |
.PP |
65 |
The second form of |
66 |
.I getinfo |
67 |
with a hyphen simply removes the header |
68 |
and copies the body of the file from the standard |
69 |
input to the standard output. |
70 |
If the |
71 |
.I \-d |
72 |
option is given, then the resolution string will be elided as well. |
73 |
.PP |
74 |
The third form of |
75 |
.I "getinfo \-a" |
76 |
adds one or more header lines to the standard input. |
77 |
These lines are given as arguments to |
78 |
.I getinfo, |
79 |
and must be quoted if they contain spaces. |
80 |
The alternative form with |
81 |
.I \-r |
82 |
replaces any previous occurances of the settings in the given |
83 |
line(s) with nothing if there is only one word, or with |
84 |
the whole line if quoted and containing interior white space or |
85 |
an equals sign ('='). |
86 |
Any leading white space matches any leading number of spaces and |
87 |
tabs in the input header. |
88 |
.PP |
89 |
The fourth form of |
90 |
.I "getinfo \-c" |
91 |
is followed by a command and its arguments, which is executed |
92 |
on the data segment of the standard input. |
93 |
The header is passed along, with the addition of the command |
94 |
at the end. |
95 |
This is roughly equivalent to the following sequence, but does not |
96 |
require the input to be in a file: |
97 |
.IP "" .2i |
98 |
( getinfo < input ; getinfo - < input | command .. ) |
99 |
.PP |
100 |
If the |
101 |
.I \+d |
102 |
option is given with |
103 |
.I \-c, |
104 |
then the resolution string will be copied before the command is called. |
105 |
If the |
106 |
.I \-d |
107 |
option is given, then the resolution string is read in but not copied. |
108 |
.SH EXAMPLES |
109 |
To print the header information from scene1.oct and scene2.hdr: |
110 |
.IP "" .2i |
111 |
getinfo scene1.oct scene2.hdr |
112 |
.PP |
113 |
To print the dimensions of a set of pictures: |
114 |
.IP "" .2i |
115 |
getinfo -d *.hdr |
116 |
.PP |
117 |
To add two header lines modifying the view |
118 |
and exposure calibration of a picture: |
119 |
.IP "" .2i |
120 |
getinfo -a "VIEW= -vta -vh 180 -vv 180" "EXPOSURE=1.5" < orig.hdr > modified.hdr |
121 |
.PP |
122 |
To remove any indented lines containing "EXPOSURE=" and replace any |
123 |
left-justified "EXPOSURE=" lines with a single value of 16: |
124 |
.IP "" .2i |
125 |
getinfo -r " EXPOSURE=" "EXPOSURE=16" < orig.hdr > fixed.hdr |
126 |
.PP |
127 |
To raise floating-point matrix elements to a power of 2.7: |
128 |
.IP "" .2i |
129 |
getinfo -c rcalc -if -of -e '$1=$1^2.7' < input.fmx > output.fmx |
130 |
.SH AUTHOR |
131 |
Greg Ward |
132 |
.SH "SEE ALSO" |
133 |
oconv(1), pfilt(1), rcalc(1), rhinfo(1), rpict(1), rsplit(1), rtrace(1), rvu(1) |
