1 |
.\" RCSid "$Id$" |
2 |
.TH GETBBOX 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
getbbox - compute bounding box for RADIANCE scene |
5 |
.SH SYNOPSIS |
6 |
.B getbbox |
7 |
8 |
.B \-w |
9 |
10 |
.B \-h |
11 |
12 |
13 |
.B "input .." |
14 |
15 |
.SH DESCRIPTION |
16 |
.I Getbbox |
17 |
reads each scene description |
18 |
.I input |
19 |
and computes the minimum axis-aligned parallelopiped that |
20 |
will enclose all of the objects. |
21 |
Each |
22 |
.I input |
23 |
can be either a file name, or a command (enclosed in quotes |
24 |
and preceded by a `!'). |
25 |
If no arguments are given, the standard input is read. |
26 |
A hyphen ('-') can also be used to indicate the standard input. |
27 |
.PP |
28 |
The |
29 |
.I \-w |
30 |
option suppresses warnings. |
31 |
The |
32 |
.I \-h |
33 |
option suppresses the header line "xmin xmax ymin ymax zmin zmax". |
34 |
.SH EXAMPLE |
35 |
To compute the bounding box for the object ``thingy'': |
36 |
.IP "" .2i |
37 |
getbbox thingy |
38 |
.PP |
39 |
To preview ``scene'': |
40 |
.IP "" .2i |
41 |
preview -v FOUR -b `getbbox -h scene` scene |
42 |
.SH NOTES |
43 |
Since expanding a scene can require considerable overhead, it |
44 |
is better to use the bounding cube produced by |
45 |
.I oconv(1) |
46 |
and read by |
47 |
.I getinfo(1) |
48 |
if an octree exists for the scene. |
49 |
However, there are certain circumstances, such as foreign object |
50 |
placement, that require knowing the bounding box rather than |
51 |
just the bounding cube. |
52 |
.SH AUTHOR |
53 |
Greg Ward |
54 |
.SH ACKNOWLEDGEMENT |
55 |
Work on this program was sponsored by the LESO |
56 |
group at EPFL in Switzerland. |
57 |
.SH "SEE ALSO" |
58 |
getinfo(1), oconv(1), xform(1) |
