root/Development/ray/doc/man/man1/getbbox.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 9 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH GETBBOX 1 11/15/93 RADIANCE
3 .SH NAME
4 getbbox - compute bounding box for RADIANCE scene
5 .SH SYNOPSIS
6 .B getbbox
7 [
8 .B \-w
9 ][
10 .B \-h
11 ]
12 [
13 .B "input .."
14 ]
15 .SH DESCRIPTION
16 .I Getbbox
17 reads each scene description
18 .I input
19 and computes the minimum axis-aligned parallelopiped that
20 will enclose all of the objects.
21 Each
22 .I input
23 can be either a file name, or a command (enclosed in quotes
24 and preceded by a `!').
25 If no arguments are given, the standard input is read.
26 A hyphen ('-') can also be used to indicate the standard input.
27 .PP
28 The
29 .I \-w
30 option suppresses warnings.
31 The
32 .I \-h
33 option suppresses the header line "xmin xmax ymin ymax zmin zmax".
34 .SH EXAMPLE
35 To compute the bounding box for the object ``thingy'':
36 .IP "" .2i
37 getbbox thingy
38 .PP
39 To preview ``scene'':
40 .IP "" .2i
41 preview -v FOUR -b `getbbox -h scene` scene
42 .SH NOTES
43 Since expanding a scene can require considerable overhead, it
44 is better to use the bounding cube produced by
45 .I oconv(1)
46 and read by
47 .I getinfo(1)
48 if an octree exists for the scene.
49 However, there are certain circumstances, such as foreign object
50 placement, that require knowing the bounding box rather than
51 just the bounding cube.
52 .SH AUTHOR
53 Greg Ward
54 .SH ACKNOWLEDGEMENT
55 Work on this program was sponsored by the LESO
56 group at EPFL in Switzerland.
57 .SH "SEE ALSO"
58 getinfo(1), oconv(1), xform(1)
