1 |
.\" RCSid "$Id: genworm.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
2 |
.TH GENWORM 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
genworm - generate a RADIANCE description of a functional worm |
5 |
.SH SYNOPSIS |
6 |
.B "genworm mat name 'x(t)' 'y(t)' 'z(t)' 'r(t)' nseg" |
7 |
8 |
.B "\-e expr" |
9 |
10 |
.B "\-f file" |
11 |
12 |
.SH DESCRIPTION |
13 |
.I Genworm |
14 |
produces a RADIANCE scene description of a |
15 |
worm defined by the parametric equations |
16 |
.I x(t), |
17 |
.I y(t), |
18 |
.I z(t), |
19 |
and |
20 |
.I r(t) |
21 |
(the radius). |
22 |
.I T |
23 |
will vary from 0 to 1 in steps of |
24 |
.I 1/nseg. |
25 |
The surface will be composed of |
26 |
.I nseg |
27 |
cones or cylinders and |
28 |
.I nseg+1 |
29 |
spheres. |
30 |
The expressions are of the same type used in RADIANCE |
31 |
function files. |
32 |
Auxiliary expressions and/or files may be specified |
33 |
in any number of |
34 |
.I \-e |
35 |
and |
36 |
.I \-f |
37 |
options. |
38 |
.SH EXAMPLE |
39 |
To generate a banana: |
40 |
.IP "" .2i |
41 |
genworm yellow banana '0' '5*sin(t)' '5*cos(t)' '.4-(.5-t)*(.5-t)' 20 |
42 |
.SH AUTHOR |
43 |
Greg Ward |
44 |
.SH BUGS |
45 |
Since the worm is constructed of intersecting surfaces, only |
46 |
opaque materials should be used with this object. |
47 |
Also, a worm cannot double back inside itself without making a mess. |
48 |
.SH "SEE ALSO" |
49 |
genbox(1), genrev(1), gensurf(1), icalc(1), rpict(1), rvu(1), xform(1) |
