--- ray/doc/man/man1/gensurf.1 2025/01/21 01:56:27 1.9 +++ ray/doc/man/man1/gensurf.1 2025/06/27 23:46:06 1.10 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: gensurf.1,v 1.9 2025/01/21 01:56:27 greg Exp $" +.\" RCSid "$Id: gensurf.1,v 1.10 2025/06/27 23:46:06 greg Exp $" .TH GENSURF 1 11/15/93 RADIANCE .SH NAME gensurf - generate a RADIANCE or Wavefront description of a curved surface @@ -22,19 +22,19 @@ gensurf - generate a RADIANCE or Wavefront description ][ .B "\-f file" ][ -.B \-s -][ .B \-i ][ +.B \-s +][ .B \-o ] .br .B "gensurf mat name dfile dfile dfile m n" [ -.B \-s -][ .B \-i ][ +.B \-s +][ .B \-o ] .SH DESCRIPTION @@ -70,12 +70,12 @@ The variable and function definitions in each .I \-f source file are read and compiled from the RADIANCE library where it is found. The +.I \-i +option reverses surface normal directions relative to the (s,t) parameters, applying +a left-hand rule, instead. +The .I \-s option adds smoothing (surface normal interpolation) to the surface. -The -.I \-i -option reverses surface normal directions from the standard -clockwise-from-front orientation. The .I \-o option produces a Wavefront .OBJ file rather than a RADIANCE
