root/radiance/ray/doc/man/man1/gensurf.1
Revision: 1.1
Committed: Tue Mar 11 19:20:21 2003 UTC (22 years, 2 months ago) by greg
Added documentation to repository
1 .\" RCSid "$Id"
2 .TH GENSURF 1 11/15/93 RADIANCE
3 .SH NAME
4 gensurf - generate a RADIANCE description of a curved surface
5 .SH SYNOPSIS
6 .B "gensurf mat name 'x(s,t)' 'y(s,t)' 'z(s,t)' m n"
7 [
8 .B "\-e expr"
9 ][
10 .B "\-f file"
11 ][
12 .B \-s
13 ]
14 .br
15 .B "gensurf mat name 'x(s,t)' 'y(s,t)' dfile m n"
16 [
17 .B "\-e expr"
18 ][
19 .B "\-f file"
20 ][
21 .B \-s
22 ]
23 .br
24 .B "gensurf mat name dfile dfile dfile m n"
25 [
26 .B \-s
27 ]
28 .SH DESCRIPTION
29 .I Gensurf
30 produces a RADIANCE scene description of a
31 functional surface defined by the parametric equations
32 .I x(s,t),
33 .I y(s,t),
34 and
35 .I z(s,t).
36 The surface normal is defined by the right hand rule as
37 applied to
38 .I (s,t).
39 .I S
40 will vary from 0 to 1 in steps of
41 .I 1/m,
42 and
43 .I t
44 will vary from 0 to 1 in steps of
45 .I 1/n.
46 The surface will be composed of
47 .I 2*m*n
48 or fewer triangles and quadrilaterals.
49 The expressions are of the same type used in RADIANCE
50 function files.
51 Auxiliary expressions and/or files may be specified
52 in any number of
53 .I \-e
54 and
55 .I \-f
56 options.
57 The
58 .I \-s
59 option adds smoothing (surface normal interpolation) to the surface.
60 .PP
61 Rough holes may be cut in the mesh by defining a valid(s,t) function.
62 Where this function is positive, polygon vertices will be produced.
63 Where it is negative, no geometry will be output.
64 Surface normal interpolation will ignore any invalid vertices.
65 .PP
66 The second invocation form reads z data values from the file
67 .I dfile.
68 This file must give either m*n or (m+1)*(n+1) floating point z
69 values.
70 If m*n values are given, then the values correspond to the centroid
71 of each quadrilateral region.
72 If (m+1)*(n+1) values are given, then the values correspond to the
73 vertices of each quadrilateral region.
74 The ordering of the data in the file is such that the s values are
75 changing faster than the t values.
76 If a minus ('-') is given for
77 .I dfile,
78 then the values are read from the standard input.
79 .PP
80 The third invocation form is used to read coordinate triplets from a
81 file or the standard input.
82 The three
83 .I dfile
84 arguments must all be the same, and the corresponding file must
85 contain three floating point values for each point location.
86 The ordering and other details are the same as those described
87 for z value files above.
88 .SH EXAMPLE
89 To generate a tesselated sphere:
90 .IP "" .2i
91 gensurf crystal ball 'sin(PI*s)*cos(2*PI*t)' 'cos(PI*s)' 'sin(PI*s)*sin(2*PI*t)' 7 10
92 .PP
93 To generate a 10x20 smoothed height field from 12 recorded vertex
94 z values:
95 .IP "" .2i
96 gensurf dirt ground '10*s' '20*t' height.dat 2 3 -s
97 .SH AUTHOR
98 Greg Ward
99 .SH BUGS
100 The smoothing operation requires that functions be defined
101 beyond the [0,1] boundaries of s and t.
102 .SH "SEE ALSO"
103 calc(1), genbox(1), genrev(1), genworm(1), rpict(1), rview(1), xform(1)
