root/radiance/ray/doc/man/man1/gensurf.1
Revision: 1.2
Committed: Tue Mar 11 22:48:20 2003 UTC (22 years, 2 months ago) by greg
Changes since 1.1: +18 -4 lines
1 .\" RCSid "$Id"
2 .TH GENSURF 1 11/15/93 RADIANCE
3 .SH NAME
4 gensurf - generate a RADIANCE or Wavefront description of a curved surface
5 .SH SYNOPSIS
6 .B "gensurf mat name 'x(s,t)' 'y(s,t)' 'z(s,t)' m n"
7 [
8 .B "\-e expr"
9 ][
10 .B "\-f file"
11 ][
12 .B \-s
13 ][
14 .B \-o
15 ]
16 .br
17 .B "gensurf mat name 'x(s,t)' 'y(s,t)' dfile m n"
18 [
19 .B "\-e expr"
20 ][
21 .B "\-f file"
22 ][
23 .B \-s
24 ][
25 .B \-o
26 ]
27 .br
28 .B "gensurf mat name dfile dfile dfile m n"
29 [
30 .B \-s
31 ][
32 .B \-o
33 ]
34 .SH DESCRIPTION
35 .I Gensurf
36 produces either a RADIANCE scene description or a Wavefront .OBJ
37 file of a functional surface defined by the parametric equations
38 .I x(s,t),
39 .I y(s,t),
40 and
41 .I z(s,t).
42 The surface normal is defined by the right hand rule as
43 applied to
44 .I (s,t).
45 .I S
46 will vary from 0 to 1 in steps of
47 .I 1/m,
48 and
49 .I t
50 will vary from 0 to 1 in steps of
51 .I 1/n.
52 The surface will be composed of
53 .I 2*m*n
54 or fewer triangles and quadrilaterals.
55 The expressions are of the same type used in RADIANCE
56 function files.
57 Auxiliary expressions and/or files may be specified
58 in any number of
59 .I \-e
60 and
61 .I \-f
62 options.
63 The
64 .I \-s
65 option adds smoothing (surface normal interpolation) to the surface.
66 The
67 .I \-o
68 option produces a Wavefront .OBJ file rather than a RADIANCE
69 scene description.
70 This is most useful as input to the
71 .I obj2mesh(1)
72 program for producing a compiled mesh.
73 .PP
74 Rough holes may be cut in the mesh by defining a valid(s,t) function.
75 Where this function is positive, polygon vertices will be produced.
76 Where it is negative, no geometry will be output.
77 Surface normal interpolation will ignore any invalid vertices.
78 .PP
79 The second invocation form reads z data values from the file
80 .I dfile.
81 This file must give either m*n or (m+1)*(n+1) floating point z
82 values.
83 If m*n values are given, then the values correspond to the centroid
84 of each quadrilateral region.
85 If (m+1)*(n+1) values are given, then the values correspond to the
86 vertices of each quadrilateral region.
87 The ordering of the data in the file is such that the s values are
88 changing faster than the t values.
89 If a minus ('-') is given for
90 .I dfile,
91 then the values are read from the standard input.
92 .PP
93 The third invocation form is used to read coordinate triplets from a
94 file or the standard input.
95 The three
96 .I dfile
97 arguments must all be the same, and the corresponding file must
98 contain three floating point values for each point location.
99 The ordering and other details are the same as those described
100 for z value files above.
101 .SH EXAMPLE
102 To generate a tesselated sphere:
103 .IP "" .2i
104 gensurf crystal ball 'sin(PI*s)*cos(2*PI*t)' 'cos(PI*s)' 'sin(PI*s)*sin(2*PI*t)' 7 10
105 .PP
106 To generate a 10x20 smoothed height field from 12 recorded vertex
107 z values:
108 .IP "" .2i
109 gensurf dirt ground '10*s' '20*t' height.dat 2 3 -s
110 .SH AUTHOR
111 Greg Ward
112 .SH BUGS
113 The smoothing operation requires that functions be defined
114 beyond the [0,1] boundaries of s and t.
115 .SH "SEE ALSO"
116 calc(1), genbox(1), genrev(1), genworm(1),
117 obj2mesh(1), rpict(1), rview(1), xform(1)
