root/Development/ray/doc/man/man1/gensurf.1
Revision: 1.8
Committed: Thu Apr 15 23:51:04 2021 UTC (4 years, 5 months ago) by greg
1 .\" RCSid "$Id: gensurf.1,v 1.7 2018/05/04 23:56:49 greg Exp $"
2 .TH GENSURF 1 11/15/93 RADIANCE
3 .SH NAME
4 gensurf - generate a RADIANCE or Wavefront description of a curved surface
5 .SH SYNOPSIS
6 .B "gensurf mat name 'x(s,t)' 'y(s,t)' 'z(s,t)' m n"
7 [
8 .B "\-e expr"
9 ][
10 .B "\-f file"
11 ][
12 .B \-s
13 ][
14 .B \-o
15 ]
16 .br
17 .B "gensurf mat name 'x(s,t)' 'y(s,t)' dfile m n"
18 [
19 .B "\-e expr"
20 ][
21 .B "\-f file"
22 ][
23 .B \-s
24 ][
25 .B \-o
26 ]
27 .br
28 .B "gensurf mat name dfile dfile dfile m n"
29 [
30 .B \-s
31 ][
32 .B \-o
33 ]
34 .SH DESCRIPTION
35 .I Gensurf
36 produces either a RADIANCE scene description or a Wavefront .OBJ
37 file of a functional surface defined by the parametric equations
38 .I x(s,t),
39 .I y(s,t),
40 and
41 .I z(s,t).
42 The surface normal is defined by the right hand rule as
43 applied to
44 .I (s,t).
45 .I S
46 will vary from 0 to 1 in steps of
47 .I 1/m,
48 and
49 .I t
50 will vary from 0 to 1 in steps of
51 .I 1/n.
52 The surface will be composed of
53 .I 2*m*n
54 or fewer triangles and quadrilaterals.
55 The expressions are of the same type used in RADIANCE
56 function files.
57 Auxiliary expressions and/or files may be specified
58 in any number of
59 .I \-e
60 and
61 .I \-f
62 options.
63 The variable and function definitions in each
64 .I \-f source
65 file are read and compiled from the RADIANCE library where it is found.
66 The
67 .I \-s
68 option adds smoothing (surface normal interpolation) to the surface.
69 The
70 .I \-o
71 option produces a Wavefront .OBJ file rather than a RADIANCE
72 scene description.
73 This is most useful as input to the
74 .I obj2mesh(1)
75 program for producing a compiled mesh.
76 A single "usemtl" statement will appear at the beginning
77 of the .OBJ output, echoing the modifier given on the command line.
78 .PP
79 Rough holes may be cut in the mesh by defining a valid(s,t) function.
80 Where this function is positive, polygon vertices will be produced.
81 Where it is negative, no geometry will be output.
82 Surface normal interpolation will ignore any invalid vertices.
83 .PP
84 The second invocation form reads z data values from the file
85 .I dfile.
86 This file must give either m*n or (m+1)*(n+1) floating point z
87 values.
88 If m*n values are given, then the values correspond to the centroid
89 of each quadrilateral region.
90 If (m+1)*(n+1) values are given, then the values correspond to the
91 vertices of each quadrilateral region.
92 The ordering of the data in the file is such that the s values are
93 changing faster than the t values.
94 If a minus ('-') is given for
95 .I dfile,
96 then the values are read from the standard input.
97 .PP
98 The third invocation form is used to read coordinate triplets from a
99 file or the standard input.
100 The three
101 .I dfile
102 arguments must all be the same, and the corresponding file must
103 contain three floating point values for each point location.
104 The ordering and other details are the same as those described
105 for z value files above.
106 .SH EXAMPLE
107 To generate a tesselated sphere:
108 .IP "" .2i
109 gensurf crystal ball 'sin(PI*s)*cos(2*PI*t)' 'cos(PI*s)' 'sin(PI*s)*sin(2*PI*t)' 7 10
110 .PP
111 To generate a 10x20 smoothed height field from 12 recorded vertex
112 z values:
113 .IP "" .2i
114 gensurf dirt ground '10*s' '20*t' height.dat 2 3 \-s
115 .SH ENVIRONMENT
116 RAYPATH the directories to check for auxiliary files.
117 .SH AUTHOR
118 Greg Ward
119 .SH BUGS
120 The smoothing operation requires that functions be defined
121 beyond the [0,1] boundaries of s and t.
122 .SH "SEE ALSO"
123 genbox(1), genrev(1), genworm(1), icalc(1),
124 obj2mesh(1), obj2rad(1), robjutil(1), rpict(1), rvu(1), xform(1)
