root/Development/ray/doc/man/man1/gensurf.1
Revision: 1.10
Committed: Fri Jun 27 23:46:06 2025 UTC (3 months, 2 weeks ago) by greg
CVS Tags: rad6R0, HEAD
Changes since 1.9: +9 -9 lines
docs(gensurf): Slight wording improvements
1 .\" RCSid "$Id: gensurf.1,v 1.9 2025/01/21 01:56:27 greg Exp $"
2 .TH GENSURF 1 11/15/93 RADIANCE
3 .SH NAME
4 gensurf - generate a RADIANCE or Wavefront description of a curved surface
5 .SH SYNOPSIS
6 .B "gensurf mat name 'x(s,t)' 'y(s,t)' 'z(s,t)' m n"
7 [
8 .B "\-e expr"
9 ][
10 .B "\-f file"
11 ][
12 .B \-s
13 ][
14 .B \-i
15 ][
16 .B \-o
17 ]
18 .br
19 .B "gensurf mat name 'x(s,t)' 'y(s,t)' dfile m n"
20 [
21 .B "\-e expr"
22 ][
23 .B "\-f file"
24 ][
25 .B \-i
26 ][
27 .B \-s
28 ][
29 .B \-o
30 ]
31 .br
32 .B "gensurf mat name dfile dfile dfile m n"
33 [
34 .B \-i
35 ][
36 .B \-s
37 ][
38 .B \-o
39 ]
40 .SH DESCRIPTION
41 .I Gensurf
42 produces either a RADIANCE scene description or a Wavefront .OBJ
43 file of a functional surface defined by the parametric equations
44 .I x(s,t),
45 .I y(s,t),
46 and
47 .I z(s,t).
48 The surface normal is defined by the right hand rule as
49 applied to
50 .I (s,t).
51 .I S
52 will vary from 0 to 1 in steps of
53 .I 1/m,
54 and
55 .I t
56 will vary from 0 to 1 in steps of
57 .I 1/n.
58 The surface will be composed of
59 .I 2*m*n
60 or fewer triangles and quadrilaterals.
61 The expressions are of the same type used in RADIANCE
62 function files.
63 Auxiliary expressions and/or files may be specified
64 in any number of
65 .I \-e
66 and
67 .I \-f
68 options.
69 The variable and function definitions in each
70 .I \-f source
71 file are read and compiled from the RADIANCE library where it is found.
72 The
73 .I \-i
74 option reverses surface normal directions relative to the (s,t) parameters, applying
75 a left-hand rule, instead.
76 The
77 .I \-s
78 option adds smoothing (surface normal interpolation) to the surface.
79 The
80 .I \-o
81 option produces a Wavefront .OBJ file rather than a RADIANCE
82 scene description.
83 This is most useful as input to the
84 .I obj2mesh(1)
85 program for producing a compiled mesh.
86 A single "usemtl" statement will appear at the beginning
87 of the .OBJ output, echoing the modifier given on the command line.
88 .PP
89 Rough holes may be cut in the mesh by defining a valid(s,t) function.
90 Where this function is positive, polygon vertices will be produced.
91 Where it is negative, no geometry will be output.
92 Surface normal interpolation will ignore any invalid vertices.
93 .PP
94 The second invocation form reads z data values from the file
95 .I dfile.
96 This file must give either m*n or (m+1)*(n+1) floating point z
97 values.
98 If m*n values are given, then the values correspond to the centroid
99 of each quadrilateral region.
100 If (m+1)*(n+1) values are given, then the values correspond to the
101 vertices of each quadrilateral region.
102 The ordering of the data in the file is such that the s values are
103 changing faster than the t values.
104 If a minus ('-') is given for
105 .I dfile,
106 then the values are read from the standard input.
107 .PP
108 The third invocation form is used to read coordinate triplets from a
109 file or the standard input.
110 The three
111 .I dfile
112 arguments must all be the same, and the corresponding file must
113 contain three floating point values for each point location.
114 The ordering and other details are the same as those described
115 for z value files above.
116 .SH EXAMPLE
117 To generate a tesselated sphere:
118 .IP "" .2i
119 gensurf crystal ball 'sin(PI*s)*cos(2*PI*t)' 'cos(PI*s)' 'sin(PI*s)*sin(2*PI*t)' 7 10
120 .PP
121 To generate a 10x20 smoothed height field from 12 recorded vertex
122 z values:
123 .IP "" .2i
124 gensurf dirt ground '10*s' '20*t' height.dat 2 3 \-s
125 .SH ENVIRONMENT
126 RAYPATH the directories to check for auxiliary files.
127 .SH AUTHOR
128 Greg Ward
129 .SH BUGS
130 The smoothing operation requires that functions be defined
131 beyond the [0,1] boundaries of s and t.
132 .SH "SEE ALSO"
133 genbox(1), genrev(1), genworm(1), icalc(1),
134 obj2mesh(1), obj2rad(1), robjutil(1), rpict(1), rvu(1), xform(1)
