| 1 |
.\" RCSid $Id: genskyvec.1,v 1.4 2012/06/28 20:48:03 greg Exp $
| 2 |
.TH GENSKYVEC 1 12/09/09 RADIANCE
| 3 |
.SH NAME
| 4 |
genskyvec - compute patch radiance averages for a specific sky
| 5 |
.SH SYNOPSIS
| 6 |
.B genskyvec
| 7 |
| 8 |
.B "\-m N"
| 9 |
| 10 |
.B "\-c r g b"
| 11 |
| 12 |
.B "\-d"
| 13 |
| 14 |
.SH DESCRIPTION
| 15 |
.I Genskyvec
| 16 |
samples the
| 17 |
.I Radinace
| 18 |
sky description given on the standard input to generate a list of
| 19 |
average patch radiances.
| 20 |
If there is a sun in the description,
| 21 |
.I genskyvec
| 22 |
will include its contribution in the three nearest sky patches,
| 23 |
distributing energy according to centroid proximity.
| 24 |
.PP
| 25 |
By default,
| 26 |
.I genskyvec
| 27 |
divides the sky into 2305 patches, plus one patch for the ground.
| 28 |
This corresponds to Reinhart's extension of the Tregenza sky,
| 29 |
where the original 145 patches are subdivided into 16 subpatches,
| 30 |
except at the zenith.
| 31 |
A different subdivision may be specified via the
| 32 |
.I \-m
| 33 |
option.
| 34 |
The value given will be used to subdivide each dimension, so the
| 35 |
default of 4 yields almost 16 times as many patches
| 36 |
as the original Tregenza sky, which can be specified with
| 37 |
.I "\-m 1."
| 38 |
A higher resolution sky is generally better for daylight
| 39 |
coefficient analysis where solar position is important.
| 40 |
.PP
| 41 |
The
| 42 |
.I \-c
| 43 |
option may be used to specify a color for the sky.
| 44 |
The gray value should equal 1 for proper energy balance
| 45 |
The default sky color is
| 46 |
.I "\-c 0.960 1.004 1.118".
| 47 |
.PP
| 48 |
The
| 49 |
.I \-d
| 50 |
option may be used to produce a sun-only vector, with no sky contributions.
| 51 |
If a time of day is selected or sky type that has no sun, then a zero vector
| 52 |
is produced.
| 53 |
.SH EXAMPLE
| 54 |
To generate 578 patches corresponding to a 2x2 subdivision of the
| 55 |
Tregenza sky on a sunny equinox noon:
| 56 |
.IP "" .2i
| 57 |
gensky 9 21 12 | genskyvec -m 2 > sky09_21_12.dat
| 58 |
.SH AUTHOR
| 59 |
Greg Ward
| 60 |
.SH "SEE ALSO"
| 61 |
dctimestep(1), genBSDF(1), gendaylit(1),
| 62 |
gendaymtx(1), gensky(1), rcontrib(1), rtrace(1)
