root/Development/ray/doc/man/man1/genskyvec.1
Revision: 1.1
Committed: Thu Dec 10 00:17:19 2009 UTC (15 years, 11 months ago) by greg
New man pages for dctimestep and genskyvec
1 .\" RCSid $Id$
2 .TH GENSKYVEC 1 12/09/09 RADIANCE
3 .SH NAME
4 genskyvec - compute patch radiance averages for a specific sky
5 .SH SYNOPSIS
6 .B genskyvec
7 [
8 .B "\-m N"
9 ][
10 .B "\-c r g b"
11 ]
12 .SH DESCRIPTION
13 .I Genskyvec
14 samples the
15 .I Radinace
16 sky description given on the standard input to generate a list of
17 average patch radiances.
18 If there is a sun in the description,
19 .I genskyvec
20 will include its contribution in the three nearest sky patches,
21 distributing energy according to centroid proximity.
22 .PP
23 By default,
24 .I genskyvec
25 divides the sky into 2305 patches, plus one patch for the ground.
26 This corresponds to Reinhart's extension of the Tregenza sky,
27 where the original 145 patches are subdivided into 16 subpatches,
28 except at the zenith.
29 A different subdivision may be specified via the
30 .I \-m
31 option.
32 The value given will be used to subdivide each dimension, so the
33 default of 4 yields almost 16 times as many patches
34 as the original Tregenza sky, which can be specified with
35 .I "\-m 1."
36 A higher resolution sky is generally better for daylight
37 coefficient analysis where solar position is important.
38 .PP
39 The
40 .I \-c
41 option may be used to specify a color for the sky.
42 The gray value should equal 1 for proper energy balance
43 The default sky color is
44 .I "\-c 0.960 1.004 1.118".
45 .SH EXAMPLE
46 To generate 578 patches corresponding to a 2x2 subdivision of the
47 Tregenza sky on a sunny equinox noon:
48 .IP "" .2i
49 gensky 9 21 12 | genskyvec -m 2 > sky09_21_12.dat
50 .SH AUTHOR
51 Greg Ward
52 .SH "SEE ALSO"
53 dctimestep(1), gensky(1), gentregvec(1), rtcontrib(1), rtrace(1)
