root/radiance/ray/doc/man/man1/genskyvec.1
Revision: 1.5
Committed: Sun Jan 20 02:07:16 2013 UTC (12 years, 3 months ago) by greg
CVS Tags: rad4R2, rad4R2P1
Added documentation for new gendaymtx tool
# User Rev Content
1 greg 1.5 .\" RCSid $Id: genskyvec.1,v 1.4 2012/06/28 20:48:03 greg Exp $
2 greg 1.1 .TH GENSKYVEC 1 12/09/09 RADIANCE
3     .SH NAME
4     genskyvec - compute patch radiance averages for a specific sky
5     .SH SYNOPSIS
6     .B genskyvec
7     [
8     .B "\-m N"
9     ][
10     .B "\-c r g b"
11 greg 1.4 ][
12     .B "\-d"
13 greg 1.1 ]
14     .SH DESCRIPTION
15     .I Genskyvec
16     samples the
17     .I Radinace
18     sky description given on the standard input to generate a list of
19     average patch radiances.
20     If there is a sun in the description,
21     .I genskyvec
22     will include its contribution in the three nearest sky patches,
23     distributing energy according to centroid proximity.
24     .PP
25     By default,
26     .I genskyvec
27     divides the sky into 2305 patches, plus one patch for the ground.
28     This corresponds to Reinhart's extension of the Tregenza sky,
29     where the original 145 patches are subdivided into 16 subpatches,
30     except at the zenith.
31     A different subdivision may be specified via the
32     .I \-m
33     option.
34     The value given will be used to subdivide each dimension, so the
35     default of 4 yields almost 16 times as many patches
36     as the original Tregenza sky, which can be specified with
37     .I "\-m 1."
38     A higher resolution sky is generally better for daylight
39     coefficient analysis where solar position is important.
40     .PP
41     The
42     .I \-c
43     option may be used to specify a color for the sky.
44     The gray value should equal 1 for proper energy balance
45     The default sky color is
46     .I "\-c 0.960 1.004 1.118".
47 greg 1.4 .PP
48     The
49     .I \-d
50     option may be used to produce a sun-only vector, with no sky contributions.
51     If a time of day is selected or sky type that has no sun, then a zero vector
52     is produced.
53 greg 1.1 .SH EXAMPLE
54     To generate 578 patches corresponding to a 2x2 subdivision of the
55     Tregenza sky on a sunny equinox noon:
56     .IP "" .2i
57     gensky 9 21 12 | genskyvec -m 2 > sky09_21_12.dat
58     .SH AUTHOR
59     Greg Ward
60     .SH "SEE ALSO"
61 greg 1.5 dctimestep(1), genBSDF(1), gendaylit(1),
62     gendaymtx(1), gensky(1), rcontrib(1), rtrace(1)
