1 |
.\" RCSid $Id: genskyvec.1,v 1.6 2014/09/17 22:40:49 greg Exp $ |
2 |
.TH GENSKYVEC 1 12/09/09 RADIANCE |
3 |
.SH NAME |
4 |
genskyvec - compute patch radiance averages for a specific sky |
5 |
.SH SYNOPSIS |
6 |
.B genskyvec |
7 |
8 |
.B "\-h" |
9 |
10 |
.B "\-m N" |
11 |
12 |
.B "\-c r g b" |
13 |
14 |
.B "\-d" |
15 |
16 |
.SH DESCRIPTION |
17 |
.I Genskyvec |
18 |
samples the |
19 |
.I Radinace |
20 |
sky description given on the standard input to generate a list of |
21 |
average patch radiances. |
22 |
If there is a sun in the description, |
23 |
.I genskyvec |
24 |
will include its contribution in the three nearest sky patches, |
25 |
distributing energy according to centroid proximity. |
26 |
.PP |
27 |
By default, |
28 |
.I genskyvec |
29 |
divides the sky into 2305 patches, plus one patch for the ground. |
30 |
This corresponds to Reinhart's extension of the Tregenza sky, |
31 |
where the original 145 patches are subdivided into 16 subpatches, |
32 |
except at the zenith. |
33 |
A different subdivision may be specified via the |
34 |
.I \-m |
35 |
option. |
36 |
The value given will be used to subdivide each dimension, so the |
37 |
default of 4 yields almost 16 times as many patches |
38 |
as the original Tregenza sky, which can be specified with |
39 |
.I "\-m 1." |
40 |
A higher resolution sky is generally better for daylight |
41 |
coefficient analysis where solar position is important. |
42 |
.PP |
43 |
The |
44 |
.I \-c |
45 |
option may be used to specify a color for the sky. |
46 |
The gray value should equal 1 for proper energy balance |
47 |
The default sky color is |
48 |
.I "\-c 0.960 1.004 1.118". |
49 |
.PP |
50 |
The |
51 |
.I \-d |
52 |
option may be used to produce a sun-only vector, with no sky contributions. |
53 |
If a time of day is selected or sky type that has no sun, then a zero vector |
54 |
is produced. |
55 |
.PP |
56 |
Normally, a header will be produced containing the number of rows and other |
57 |
information required by |
58 |
.I dctimestep(1). |
59 |
The |
60 |
.I \-h |
61 |
option may be used to elide this information header, producing data values only. |
62 |
.SH EXAMPLE |
63 |
To generate 578 patches corresponding to a 2x2 subdivision of the |
64 |
Tregenza sky on a sunny equinox noon: |
65 |
.IP "" .2i |
66 |
gensky 9 21 12 | genskyvec -m 2 > sky09_21_12.dat |
67 |
.SH AUTHOR |
68 |
Greg Ward |
69 |
.SH "SEE ALSO" |
70 |
dctimestep(1), genBSDF(1), gendaylit(1), |
71 |
gendaymtx(1), gensky(1), rcollate(1), rcontrib(1), |
72 |
rmtxcomb(1), rmtxop(1), rtrace(1) |
