--- ray/doc/man/man1/gensky.1 2004/01/01 19:31:44 1.4 +++ ray/doc/man/man1/gensky.1 2004/09/10 18:19:24 1.5 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: gensky.1,v 1.4 2004/01/01 19:31:44 greg Exp $" +.\" RCSid "$Id: gensky.1,v 1.5 2004/09/10 18:19:24 greg Exp $" .TH GENSKY 1 4/24/98 RADIANCE .SH NAME gensky - generate a RADIANCE description of the sky @@ -211,7 +211,7 @@ degrees west of Greenwich. (Use negative angle for east.) This is used in the calculation of solar time. Be sure to give the correct longitude also! -If solar time is given directly, then this option has no effect. +If a time zone or solar time is given directly, then this option has no effect. .SH EXAMPLE To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a site latitude of 42 degrees, 89 degrees west longitude:
