--- ray/doc/man/man1/gensky.1 2003/12/09 15:59:06 1.3 +++ ray/doc/man/man1/gensky.1 2004/09/10 18:19:24 1.5 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: gensky.1,v 1.3 2003/12/09 15:59:06 greg Exp $" +.\" RCSid "$Id: gensky.1,v 1.5 2004/09/10 18:19:24 greg Exp $" .TH GENSKY 1 4/24/98 RADIANCE .SH NAME gensky - generate a RADIANCE description of the sky @@ -97,7 +97,7 @@ suggests an ambient value in a comment at the beginnin description to use with the .I \-av option of the RADIANCE rendering programs. -(See rview(1) and rpict(1).) +(See rvu(1) and rpict(1).) This value is the cosine-weighted radiance of the sky in watts/steradian/meter2. .PP @@ -211,7 +211,7 @@ degrees west of Greenwich. (Use negative angle for east.) This is used in the calculation of solar time. Be sure to give the correct longitude also! -If solar time is given directly, then this option has no effect. +If a time zone or solar time is given directly, then this option has no effect. .SH EXAMPLE To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a site latitude of 42 degrees, 89 degrees west longitude: @@ -227,4 +227,4 @@ gensky -ang 23 -40 -s .SH AUTHOR Greg Ward .SH "SEE ALSO" -rpict(1), rview(1), xform(1) +rpict(1), rvu(1), xform(1)
