root/Development/ray/doc/man/man1/gensky.1
Revision: 1.7
Committed: Thu Nov 7 23:16:17 2019 UTC (6 years ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, HEAD
Changes since 1.6: +6 -1 lines
Added year specification for more accurate Michalsky solar position
1 .\" RCSid "$Id: gensky.1,v 1.6 2007/09/04 17:36:40 greg Exp $"
2 .TH GENSKY 1 4/24/98 RADIANCE
3 .SH NAME
4 gensky - generate a RADIANCE description of the sky
5 .SH SYNOPSIS
6 .B "gensky month day time"
7 [
8 .B options
9 ]
10 .br
11 .B "gensky -ang altitude azimuth"
12 [
13 .B options
14 ]
15 .br
16 .B "gensky -defaults"
17 .SH DESCRIPTION
18 .I Gensky
19 produces a RADIANCE scene description for the CIE standard
20 sky distribution at the given month, day and time.
21 By default, the time is interpreted as local standard
22 time on a 24-hour clock.
23 The time value may be given either as decimal hours, or using a
24 colon to separate hours and minutes.
25 If the time is immediately followed (no white space)
26 by a North American or European time zone designation,
27 then this determines the standard meridian, which may
28 be specified alternatively with the
29 .I \-m
30 option.
31 The following time zones are understood, with their corresponding
32 hour differences from Greenwich Mean Time:
33 .sp .5
34 .nf
35 Standard time:
36 YST PST MST CST EST GMT
37 9 8 7 6 5 0
38
39 CET EET AST GST IST JST NZST
40 \-1 \-2 \-3 \-4 \-5.5 \-9 \-12
41
42 Daylight savings time:
43 YDT PDT MDT CDT EDT BST
44 8 7 6 5 4 \-1
45
46 CEST EEST ADT GDT IDT JDT NZDT
47 \-2 \-3 \-4 \-5 \-6.5 \-10 \-13
48 .fi
49 .PP
50 If the time is preceded by a plus sign ('+'), then it is interpreted
51 as local solar time instead.
52 It is very important to specify the correct latitude and longitude
53 (unless local solar time is given) using the
54 .I \-a
55 and
56 .I \-o
57 options to get the correct solar angles.
58 .PP
59 The second form gives the solar angles explicitly.
60 The altitude is measured in degrees above the horizon, and the
61 azimuth is measured in degrees west of South.
62 .PP
63 The third form prints the default option values.
64 .PP
65 The output sky distribution is given as a brightness function,
66 .I skyfunc.
67 Its value is in watts/steradian/meter2.
68 The x axis points east,
69 the y axis points north, and the z axis corresponds to the zenith.
70 The actual material and surface(s) used for the sky is left
71 up to the user.
72 For a hemispherical blue sky, the description might be:
73 .sp
74 .nf
75 !gensky 4 1 14
76
77 skyfunc glow skyglow
78 0
79 0
80 4 .99 .99 1.1 0
81
82 skyglow source sky
83 0
84 0
85 4 0 0 1 180
86 .fi
87 .sp
88 Often,
89 .I skyfunc
90 will actually be used to characterize the light coming in from
91 a window.
92 .PP
93 In addition to the specification of
94 a sky distribution function,
95 .I gensky
96 suggests an ambient value in a comment at the beginning of the
97 description to use with the
98 .I \-av
99 option of the RADIANCE rendering programs.
100 (See rvu(1) and rpict(1).)
101 This value is the cosine-weighted radiance of the sky in
102 watts/steradian/meter2.
103 .PP
104 .I Gensky
105 supports the following options.
106 .TP 10n
107 .BR \-y \ year
108 If the year is specified, a more accurate solar position algorithm
109 [Michalsky 1988] will be used in place of the formula in the IES
110 Lighting Handbook.
111 .TP
112 .BR \-s
113 Sunny sky without sun.
114 The sky distribution will correspond to a standard CIE clear day.
115 .TP
116 .BR \+s
117 Sunny sky with sun.
118 In addition to the sky distribution function, a source
119 description of the sun is generated.
120 .TP
121 .BR \-c
122 Cloudy sky.
123 The sky distribution will correspond to a standard CIE overcast day.
124 .TP
125 .BR \-i
126 Intermediate sky without sun.
127 The sky will correspond to a standard CIE intermediate day.
128 .TP
129 .BR \+i
130 Intermediate sky with sun.
131 In addition to the sky distribution, a (somewhat subdued) sun
132 is generated.
133 .TP
134 .BR \-u
135 Uniform cloudy sky.
136 The sky distribution will be completely uniform.
137 .TP
138 .BI -g \ rfl
139 Average ground reflectance is
140 .I rfl.
141 This value is used to compute
142 .I skyfunc
143 when Dz is negative.
144 Ground plane brightness is the same for
145 .I \-s
146 as for
147 .I \+s.
148 (Likewise for
149 .I \-i
150 and
151 .I \+i,
152 but see the
153 .I \-r
154 option below.)
155 .TP
156 .BI -b \ brt
157 The zenith brightness is
158 .I brt.
159 Zenith radiance (in watts/steradian/meter2) is normally computed
160 from the sun angle and sky turbidity (for sunny sky).
161 It can be given directly instead, using this option.
162 .TP
163 .BI -B \ irrad
164 Same as
165 .I \-b,
166 except zenith brightness is computed from the horizontal
167 diffuse irradiance (in watts/meter2).
168 .TP
169 .BI -r \ rad
170 The solar radiance is
171 .I rad.
172 Solar radiance (in watts/steradian/meter2) is normally computed from
173 the solar altitude.
174 This option may be used to override the default calculation.
175 If a value of zero is given, no sun description is produced, and the
176 contribution of direct solar to ground brightness is neglected.
177 .TP
178 .BI -R \ irrad
179 Same as
180 .I \-r,
181 except solar radiance is computed from the horizontal direct
182 irradiance (in watts/meter2).
183 .TP
184 .BI -t \ trb
185 The turbidity factor is
186 .I trb.
187 Greater turbidity factors
188 correspond to greater atmospheric scattering.
189 A turbidity factor of 1.0 indicates an ideal clear atmosphere (i.e.
190 a completely dark sky).
191 Values less than 1.0 are physically impossible.
192 .PP
193 The following options do not apply when the solar
194 altitude and azimuth are given explicitly.
195 .TP
196 .BI -a \ lat
197 The site latitude is
198 .I lat
199 degrees north.
200 (Use negative angle for south latitude.)
201 This is used in the calculation of sun angle.
202 .TP
203 .BI -o \ lon
204 The site longitude is
205 .I lon
206 degrees west.
207 (Use negative angle for east longitude.)
208 This is used in the calculation of solar time and sun angle.
209 Be sure to give the corresponding standard meridian also!
210 If solar time is given directly, then this option has no effect.
211 .TP
212 .BI -m \ mer
213 The site standard meridian is
214 .I mer
215 degrees west of Greenwich.
216 (Use negative angle for east.)
217 This is used in the calculation of solar time.
218 Be sure to give the correct longitude also!
219 If a time zone or solar time is given directly, then this option has no effect.
220 .SH EXAMPLE
221 To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a
222 site latitude of 42 degrees, 89 degrees west longitude:
223 .IP "" .2i
224 gensky 7 4 14:30EDT +s \-a 42 \-o 89
225 .PP
226 To produce a sunny sky distribution for a specific sun position but
227 without the sun description:
228 .IP "" .2i
229 gensky \-ang 23 \-40 \-s
230 .SH FILES
231 /usr/local/lib/ray/skybright.cal
232 .SH AUTHOR
233 Greg Ward
234 .SH "SEE ALSO"
235 rpict(1), rvu(1), xform(1)
