1 |
.\" RCSid "$Id: gensky.1,v 1.5 2004/09/10 18:19:24 greg Exp $" |
2 |
.TH GENSKY 1 4/24/98 RADIANCE |
3 |
.SH NAME |
4 |
gensky - generate a RADIANCE description of the sky |
5 |
.SH SYNOPSIS |
6 |
.B "gensky month day time" |
7 |
8 |
.B options |
9 |
10 |
.br |
11 |
.B "gensky -ang altitude azimuth" |
12 |
13 |
.B options |
14 |
15 |
.br |
16 |
.B "gensky -defaults" |
17 |
.SH DESCRIPTION |
18 |
.I Gensky |
19 |
produces a RADIANCE scene description for the CIE standard |
20 |
sky distribution at the given month, day and time. |
21 |
By default, the time is interpreted as local standard |
22 |
time on a 24-hour clock. |
23 |
The time value may be given either as decimal hours, or using a |
24 |
colon to separate hours and minutes. |
25 |
If the time is immediately followed (no white space) |
26 |
by a North American or European time zone designation, |
27 |
then this determines the standard meridian, which may |
28 |
be specified alternatively with the |
29 |
.I \-m |
30 |
option. |
31 |
The following time zones are understood, with their corresponding |
32 |
hour differences from Greenwich Mean Time: |
33 |
.sp .5 |
34 |
.nf |
35 |
Standard time: |
36 |
YST PST MST CST EST GMT |
37 |
9 8 7 6 5 0 |
38 |
39 |
CET EET AST GST IST JST NZST |
40 |
\-1 \-2 \-3 \-4 \-5.5 \-9 \-12 |
41 |
42 |
Daylight savings time: |
43 |
YDT PDT MDT CDT EDT BST |
44 |
8 7 6 5 4 \-1 |
45 |
46 |
CEST EEST ADT GDT IDT JDT NZDT |
47 |
\-2 \-3 \-4 \-5 \-6.5 \-10 \-13 |
48 |
.fi |
49 |
.PP |
50 |
If the time is preceded by a plus sign ('+'), then it is interpreted |
51 |
as local solar time instead. |
52 |
It is very important to specify the correct latitude and longitude |
53 |
(unless local solar time is given) using the |
54 |
.I \-a |
55 |
and |
56 |
.I \-o |
57 |
options to get the correct solar angles. |
58 |
.PP |
59 |
The second form gives the solar angles explicitly. |
60 |
The altitude is measured in degrees above the horizon, and the |
61 |
azimuth is measured in degrees west of South. |
62 |
.PP |
63 |
The third form prints the default option values. |
64 |
.PP |
65 |
The output sky distribution is given as a brightness function, |
66 |
.I skyfunc. |
67 |
Its value is in watts/steradian/meter2. |
68 |
The x axis points east, |
69 |
the y axis points north, and the z axis corresponds to the zenith. |
70 |
The actual material and surface(s) used for the sky is left |
71 |
up to the user. |
72 |
For a hemispherical blue sky, the description might be: |
73 |
.sp |
74 |
.nf |
75 |
!gensky 4 1 14 |
76 |
77 |
skyfunc glow skyglow |
78 |
0 |
79 |
0 |
80 |
4 .99 .99 1.1 0 |
81 |
82 |
skyglow source sky |
83 |
0 |
84 |
0 |
85 |
4 0 0 1 180 |
86 |
.fi |
87 |
.sp |
88 |
Often, |
89 |
.I skyfunc |
90 |
will actually be used to characterize the light coming in from |
91 |
a window. |
92 |
.PP |
93 |
In addition to the specification of |
94 |
a sky distribution function, |
95 |
.I gensky |
96 |
suggests an ambient value in a comment at the beginning of the |
97 |
description to use with the |
98 |
.I \-av |
99 |
option of the RADIANCE rendering programs. |
100 |
(See rvu(1) and rpict(1).) |
101 |
This value is the cosine-weighted radiance of the sky in |
102 |
103 |
.PP |
104 |
.I Gensky |
105 |
supports the following options. |
106 |
.TP 10n |
107 |
.BR \-s |
108 |
Sunny sky without sun. |
109 |
The sky distribution will correspond to a standard CIE clear day. |
110 |
.TP |
111 |
.BR \+s |
112 |
Sunny sky with sun. |
113 |
In addition to the sky distribution function, a source |
114 |
description of the sun is generated. |
115 |
.TP |
116 |
.BR \-c |
117 |
Cloudy sky. |
118 |
The sky distribution will correspond to a standard CIE overcast day. |
119 |
.TP |
120 |
.BR \-i |
121 |
Intermediate sky without sun. |
122 |
The sky will correspond to a standard CIE intermediate day. |
123 |
.TP |
124 |
.BR \+i |
125 |
Intermediate sky with sun. |
126 |
In addition to the sky distribution, a (somewhat subdued) sun |
127 |
is generated. |
128 |
.TP |
129 |
.BR \-u |
130 |
Uniform cloudy sky. |
131 |
The sky distribution will be completely uniform. |
132 |
.TP |
133 |
.BI -g \ rfl |
134 |
Average ground reflectance is |
135 |
.I rfl. |
136 |
This value is used to compute |
137 |
.I skyfunc |
138 |
when Dz is negative. |
139 |
Ground plane brightness is the same for |
140 |
.I \-s |
141 |
as for |
142 |
.I \+s. |
143 |
(Likewise for |
144 |
.I \-i |
145 |
and |
146 |
.I \+i, |
147 |
but see the |
148 |
.I \-r |
149 |
option below.) |
150 |
.TP |
151 |
.BI -b \ brt |
152 |
The zenith brightness is |
153 |
.I brt. |
154 |
Zenith radiance (in watts/steradian/meter2) is normally computed |
155 |
from the sun angle and sky turbidity (for sunny sky). |
156 |
It can be given directly instead, using this option. |
157 |
.TP |
158 |
.BI -B \ irrad |
159 |
Same as |
160 |
.I \-b, |
161 |
except zenith brightness is computed from the horizontal |
162 |
diffuse irradiance (in watts/meter2). |
163 |
.TP |
164 |
.BI -r \ rad |
165 |
The solar radiance is |
166 |
.I rad. |
167 |
Solar radiance (in watts/steradian/meter2) is normally computed from |
168 |
the solar altitude. |
169 |
This option may be used to override the default calculation. |
170 |
If a value of zero is given, no sun description is produced, and the |
171 |
contribution of direct solar to ground brightness is neglected. |
172 |
.TP |
173 |
.BI -R \ irrad |
174 |
Same as |
175 |
.I \-r, |
176 |
except solar radiance is computed from the horizontal direct |
177 |
178 |
.TP |
179 |
.BI -t \ trb |
180 |
The turbidity factor is |
181 |
.I trb. |
182 |
Greater turbidity factors |
183 |
correspond to greater atmospheric scattering. |
184 |
A turbidity factor of 1.0 indicates an ideal clear atmosphere (i.e. |
185 |
a completely dark sky). |
186 |
Values less than 1.0 are physically impossible. |
187 |
.PP |
188 |
The following options do not apply when the solar |
189 |
altitude and azimuth are given explicitly. |
190 |
.TP |
191 |
.BI -a \ lat |
192 |
The site latitude is |
193 |
.I lat |
194 |
degrees north. |
195 |
(Use negative angle for south latitude.) |
196 |
This is used in the calculation of sun angle. |
197 |
.TP |
198 |
.BI -o \ lon |
199 |
The site longitude is |
200 |
.I lon |
201 |
degrees west. |
202 |
(Use negative angle for east longitude.) |
203 |
This is used in the calculation of solar time and sun angle. |
204 |
Be sure to give the corresponding standard meridian also! |
205 |
If solar time is given directly, then this option has no effect. |
206 |
.TP |
207 |
.BI -m \ mer |
208 |
The site standard meridian is |
209 |
.I mer |
210 |
degrees west of Greenwich. |
211 |
(Use negative angle for east.) |
212 |
This is used in the calculation of solar time. |
213 |
Be sure to give the correct longitude also! |
214 |
If a time zone or solar time is given directly, then this option has no effect. |
215 |
.SH EXAMPLE |
216 |
To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a |
217 |
site latitude of 42 degrees, 89 degrees west longitude: |
218 |
.IP "" .2i |
219 |
gensky 7 4 14:30EDT +s \-a 42 \-o 89 |
220 |
.PP |
221 |
To produce a sunny sky distribution for a specific sun position but |
222 |
without the sun description: |
223 |
.IP "" .2i |
224 |
gensky \-ang 23 \-40 \-s |
225 |
.SH FILES |
226 |
/usr/local/lib/ray/skybright.cal |
227 |
.SH AUTHOR |
228 |
Greg Ward |
229 |
.SH "SEE ALSO" |
230 |
rpict(1), rvu(1), xform(1) |
