root/radiance/ray/doc/man/man1/gensky.1
Revision: 1.5
Committed: Fri Sep 10 18:19:24 2004 UTC (20 years, 7 months ago) by greg
CVS Tags: rad3R7P2, rad3R7P1, rad3R6, rad3R6P1, rad3R8
# User Rev Content
1 greg 1.5 .\" RCSid "$Id: gensky.1,v 1.4 2004/01/01 19:31:44 greg Exp $"
2 greg 1.1 .TH GENSKY 1 4/24/98 RADIANCE
3     .SH NAME
4     gensky - generate a RADIANCE description of the sky
5     .SH SYNOPSIS
6     .B "gensky month day time"
7     [
8     .B options
9     ]
10     .br
11     .B "gensky -ang altitude azimuth"
12     [
13     .B options
14     ]
15     .br
16     .B "gensky -defaults"
17     .SH DESCRIPTION
18     .I Gensky
19     produces a RADIANCE scene description for the CIE standard
20     sky distribution at the given month, day and time.
21     By default, the time is interpreted as local standard
22     time on a 24-hour clock.
23     The time value may be given either as decimal hours, or using a
24     colon to separate hours and minutes.
25     If the time is immediately followed (no white space)
26     by a North American or European time zone designation,
27     then this determines the standard meridian, which may
28     be specified alternatively with the
29     .I \-m
30     option.
31     The following time zones are understood, with their corresponding
32     hour differences from Greenwich Mean Time:
33     .sp .5
34     .nf
35     Standard time:
36     YST PST MST CST EST GMT
37     9 8 7 6 5 0
38
39     CET EET AST GST IST JST NZST
40     -1 -2 -3 -4 -5.5 -9 -12
41
42     Daylight savings time:
43     YDT PDT MDT CDT EDT BST
44     8 7 6 5 4 -1
45
46     CEST EEST ADT GDT IDT JDT NZDT
47     -2 -3 -4 -5 -6.5 -10 -13
48     .fi
49     .PP
50     If the time is preceded by a plus sign ('+'), then it is interpreted
51     as local solar time instead.
52     It is very important to specify the correct latitude and longitude
53     (unless local solar time is given) using the
54     .I \-a
55     and
56     .I \-o
57     options to get the correct solar angles.
58     .PP
59     The second form gives the solar angles explicitly.
60     The altitude is measured in degrees above the horizon, and the
61     azimuth is measured in degrees west of South.
62     .PP
63     The third form prints the default option values.
64     .PP
65     The output sky distribution is given as a brightness function,
66     .I skyfunc.
67     Its value is in watts/steradian/meter2.
68     The x axis points east,
69     the y axis points north, and the z axis corresponds to the zenith.
70     The actual material and surface(s) used for the sky is left
71     up to the user.
72     For a hemispherical blue sky, the description might be:
73     .sp
74     .nf
75     !gensky 4 1 14
76
77     skyfunc glow skyglow
78     0
79     0
80 greg 1.2 4 .99 .99 1.1 0
81 greg 1.1
82     skyglow source sky
83     0
84     0
85     4 0 0 1 180
86     .fi
87     .sp
88     Often,
89     .I skyfunc
90     will actually be used to characterize the light coming in from
91     a window.
92     .PP
93     In addition to the specification of
94     a sky distribution function,
95     .I gensky
96     suggests an ambient value in a comment at the beginning of the
97     description to use with the
98     .I \-av
99     option of the RADIANCE rendering programs.
100 greg 1.4 (See rvu(1) and rpict(1).)
101 greg 1.1 This value is the cosine-weighted radiance of the sky in
102     watts/steradian/meter2.
103     .PP
104     .I Gensky
105     supports the following options.
106     .TP 10n
107     .BR \-s
108     Sunny sky without sun.
109     The sky distribution will correspond to a standard CIE clear day.
110     .TP
111     .BR \+s
112     Sunny sky with sun.
113     In addition to the sky distribution function, a source
114     description of the sun is generated.
115     .TP
116     .BR \-c
117     Cloudy sky.
118     The sky distribution will correspond to a standard CIE overcast day.
119     .TP
120     .BR \-i
121     Intermediate sky without sun.
122     The sky will correspond to a standard CIE intermediate day.
123     .TP
124     .BR \+i
125     Intermediate sky with sun.
126     In addition to the sky distribution, a (somewhat subdued) sun
127     is generated.
128     .TP
129     .BR \-u
130     Uniform cloudy sky.
131     The sky distribution will be completely uniform.
132     .TP
133     .BI -g \ rfl
134     Average ground reflectance is
135     .I rfl.
136     This value is used to compute
137     .I skyfunc
138     when Dz is negative.
139     Ground plane brightness is the same for
140     .I \-s
141     as for
142     .I \+s.
143     (Likewise for
144     .I \-i
145     and
146     .I \+i,
147     but see the
148     .I \-r
149     option below.)
150     .TP
151     .BI -b \ brt
152     The zenith brightness is
153     .I brt.
154     Zenith radiance (in watts/steradian/meter2) is normally computed
155     from the sun angle and sky turbidity (for sunny sky).
156     It can be given directly instead, using this option.
157     .TP
158     .BI -B \ irrad
159     Same as
160     .I \-b,
161     except zenith brightness is computed from the horizontal
162     diffuse irradiance (in watts/meter2).
163     .TP
164     .BI -r \ rad
165     The solar radiance is
166     .I rad.
167     Solar radiance (in watts/steradian/meter2) is normally computed from
168     the solar altitude.
169     This option may be used to override the default calculation.
170     If a value of zero is given, no sun description is produced, and the
171     contribution of direct solar to ground brightness is neglected.
172     .TP
173     .BI -R \ irrad
174     Same as
175     .I \-r,
176     except solar radiance is computed from the horizontal direct
177     irradiance (in watts/meter2).
178     .TP
179     .BI -t \ trb
180     The turbidity factor is
181     .I trb.
182     Greater turbidity factors
183     correspond to greater atmospheric scattering.
184     A turbidity factor of 1.0 indicates an ideal clear atmosphere (i.e.
185     a completely dark sky).
186     Values less than 1.0 are physically impossible.
187     .PP
188     The following options do not apply when the solar
189     altitude and azimuth are given explicitly.
190     .TP
191     .BI -a \ lat
192     The site latitude is
193     .I lat
194     degrees north.
195     (Use negative angle for south latitude.)
196     This is used in the calculation of sun angle.
197     .TP
198     .BI -o \ lon
199     The site longitude is
200     .I lon
201     degrees west.
202     (Use negative angle for east longitude.)
203     This is used in the calculation of solar time and sun angle.
204     Be sure to give the corresponding standard meridian also!
205     If solar time is given directly, then this option has no effect.
206     .TP
207     .BI -m \ mer
208     The site standard meridian is
209     .I mer
210     degrees west of Greenwich.
211     (Use negative angle for east.)
212     This is used in the calculation of solar time.
213     Be sure to give the correct longitude also!
214 greg 1.5 If a time zone or solar time is given directly, then this option has no effect.
215 greg 1.1 .SH EXAMPLE
216     To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a
217     site latitude of 42 degrees, 89 degrees west longitude:
218     .IP "" .2i
219     gensky 7 4 14:30EDT +s -a 42 -o 89
220     .PP
221     To produce a sunny sky distribution for a specific sun position but
222     without the sun description:
223     .IP "" .2i
224     gensky -ang 23 -40 -s
225     .SH FILES
226     /usr/local/lib/ray/skybright.cal
227     .SH AUTHOR
228     Greg Ward
229     .SH "SEE ALSO"
230 greg 1.4 rpict(1), rvu(1), xform(1)
