root/Development/ray/doc/man/man1/gensky.1
Revision: 1.2
Committed: Thu May 22 16:14:24 2003 UTC (22 years, 4 months ago) by greg
Corrected specification for sky color
1 .\" RCSid "$Id"
2 .TH GENSKY 1 4/24/98 RADIANCE
3 .SH NAME
4 gensky - generate a RADIANCE description of the sky
5 .SH SYNOPSIS
6 .B "gensky month day time"
7 [
8 .B options
9 ]
10 .br
11 .B "gensky -ang altitude azimuth"
12 [
13 .B options
14 ]
15 .br
16 .B "gensky -defaults"
17 .SH DESCRIPTION
18 .I Gensky
19 produces a RADIANCE scene description for the CIE standard
20 sky distribution at the given month, day and time.
21 By default, the time is interpreted as local standard
22 time on a 24-hour clock.
23 The time value may be given either as decimal hours, or using a
24 colon to separate hours and minutes.
25 If the time is immediately followed (no white space)
26 by a North American or European time zone designation,
27 then this determines the standard meridian, which may
28 be specified alternatively with the
29 .I \-m
30 option.
31 The following time zones are understood, with their corresponding
32 hour differences from Greenwich Mean Time:
33 .sp .5
34 .nf
35 Standard time:
36 YST PST MST CST EST GMT
37 9 8 7 6 5 0
38
39 CET EET AST GST IST JST NZST
40 -1 -2 -3 -4 -5.5 -9 -12
41
42 Daylight savings time:
43 YDT PDT MDT CDT EDT BST
44 8 7 6 5 4 -1
45
46 CEST EEST ADT GDT IDT JDT NZDT
47 -2 -3 -4 -5 -6.5 -10 -13
48 .fi
49 .PP
50 If the time is preceded by a plus sign ('+'), then it is interpreted
51 as local solar time instead.
52 It is very important to specify the correct latitude and longitude
53 (unless local solar time is given) using the
54 .I \-a
55 and
56 .I \-o
57 options to get the correct solar angles.
58 .PP
59 The second form gives the solar angles explicitly.
60 The altitude is measured in degrees above the horizon, and the
61 azimuth is measured in degrees west of South.
62 .PP
63 The third form prints the default option values.
64 .PP
65 The output sky distribution is given as a brightness function,
66 .I skyfunc.
67 Its value is in watts/steradian/meter2.
68 The x axis points east,
69 the y axis points north, and the z axis corresponds to the zenith.
70 The actual material and surface(s) used for the sky is left
71 up to the user.
72 For a hemispherical blue sky, the description might be:
73 .sp
74 .nf
75 !gensky 4 1 14
76
77 skyfunc glow skyglow
78 0
79 0
80 4 .99 .99 1.1 0
81
82 skyglow source sky
83 0
84 0
85 4 0 0 1 180
86 .fi
87 .sp
88 Often,
89 .I skyfunc
90 will actually be used to characterize the light coming in from
91 a window.
92 .PP
93 In addition to the specification of
94 a sky distribution function,
95 .I gensky
96 suggests an ambient value in a comment at the beginning of the
97 description to use with the
98 .I \-av
99 option of the RADIANCE rendering programs.
100 (See rview(1) and rpict(1).)
101 This value is the cosine-weighted radiance of the sky in
102 watts/steradian/meter2.
103 .PP
104 .I Gensky
105 supports the following options.
106 .TP 10n
107 .BR \-s
108 Sunny sky without sun.
109 The sky distribution will correspond to a standard CIE clear day.
110 .TP
111 .BR \+s
112 Sunny sky with sun.
113 In addition to the sky distribution function, a source
114 description of the sun is generated.
115 .TP
116 .BR \-c
117 Cloudy sky.
118 The sky distribution will correspond to a standard CIE overcast day.
119 .TP
120 .BR \-i
121 Intermediate sky without sun.
122 The sky will correspond to a standard CIE intermediate day.
123 .TP
124 .BR \+i
125 Intermediate sky with sun.
126 In addition to the sky distribution, a (somewhat subdued) sun
127 is generated.
128 .TP
129 .BR \-u
130 Uniform cloudy sky.
131 The sky distribution will be completely uniform.
132 .TP
133 .BI -g \ rfl
134 Average ground reflectance is
135 .I rfl.
136 This value is used to compute
137 .I skyfunc
138 when Dz is negative.
139 Ground plane brightness is the same for
140 .I \-s
141 as for
142 .I \+s.
143 (Likewise for
144 .I \-i
145 and
146 .I \+i,
147 but see the
148 .I \-r
149 option below.)
150 .TP
151 .BI -b \ brt
152 The zenith brightness is
153 .I brt.
154 Zenith radiance (in watts/steradian/meter2) is normally computed
155 from the sun angle and sky turbidity (for sunny sky).
156 It can be given directly instead, using this option.
157 .TP
158 .BI -B \ irrad
159 Same as
160 .I \-b,
161 except zenith brightness is computed from the horizontal
162 diffuse irradiance (in watts/meter2).
163 .TP
164 .BI -r \ rad
165 The solar radiance is
166 .I rad.
167 Solar radiance (in watts/steradian/meter2) is normally computed from
168 the solar altitude.
169 This option may be used to override the default calculation.
170 If a value of zero is given, no sun description is produced, and the
171 contribution of direct solar to ground brightness is neglected.
172 .TP
173 .BI -R \ irrad
174 Same as
175 .I \-r,
176 except solar radiance is computed from the horizontal direct
177 irradiance (in watts/meter2).
178 .TP
179 .BI -t \ trb
180 The turbidity factor is
181 .I trb.
182 Greater turbidity factors
183 correspond to greater atmospheric scattering.
184 A turbidity factor of 1.0 indicates an ideal clear atmosphere (i.e.
185 a completely dark sky).
186 Values less than 1.0 are physically impossible.
187 .PP
188 The following options do not apply when the solar
189 altitude and azimuth are given explicitly.
190 .TP
191 .BI -a \ lat
192 The site latitude is
193 .I lat
194 degrees north.
195 (Use negative angle for south latitude.)
196 This is used in the calculation of sun angle.
197 .TP
198 .BI -o \ lon
199 The site longitude is
200 .I lon
201 degrees west.
202 (Use negative angle for east longitude.)
203 This is used in the calculation of solar time and sun angle.
204 Be sure to give the corresponding standard meridian also!
205 If solar time is given directly, then this option has no effect.
206 .TP
207 .BI -m \ mer
208 The site standard meridian is
209 .I mer
210 degrees west of Greenwich.
211 (Use negative angle for east.)
212 This is used in the calculation of solar time.
213 Be sure to give the correct longitude also!
214 If solar time is given directly, then this option has no effect.
215 .SH EXAMPLE
216 To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a
217 site latitude of 42 degrees, 89 degrees west longitude:
218 .IP "" .2i
219 gensky 7 4 14:30EDT +s -a 42 -o 89
220 .PP
221 To produce a sunny sky distribution for a specific sun position but
222 without the sun description:
223 .IP "" .2i
224 gensky -ang 23 -40 -s
225 .SH FILES
226 /usr/local/lib/ray/skybright.cal
227 .SH AUTHOR
228 Greg Ward
229 .SH "SEE ALSO"
230 rpict(1), rview(1), xform(1)
