| 1 |
greg |
1.7 |
.\" RCSid "$Id: gensky.1,v 1.6 2007/09/04 17:36:40 greg Exp $" |
| 2 |
greg |
1.1 |
.TH GENSKY 1 4/24/98 RADIANCE |
| 3 |
.SH NAME |
| 4 |
gensky - generate a RADIANCE description of the sky |
| 5 |
.SH SYNOPSIS |
| 6 |
.B "gensky month day time" |
| 7 |
| 8 |
.B options |
| 9 |
| 10 |
.br |
| 11 |
.B "gensky -ang altitude azimuth" |
| 12 |
| 13 |
.B options |
| 14 |
| 15 |
.br |
| 16 |
.B "gensky -defaults" |
| 17 |
.SH DESCRIPTION |
| 18 |
.I Gensky |
| 19 |
produces a RADIANCE scene description for the CIE standard |
| 20 |
sky distribution at the given month, day and time. |
| 21 |
By default, the time is interpreted as local standard |
| 22 |
time on a 24-hour clock. |
| 23 |
The time value may be given either as decimal hours, or using a |
| 24 |
colon to separate hours and minutes. |
| 25 |
If the time is immediately followed (no white space) |
| 26 |
by a North American or European time zone designation, |
| 27 |
then this determines the standard meridian, which may |
| 28 |
be specified alternatively with the |
| 29 |
.I \-m |
| 30 |
option. |
| 31 |
The following time zones are understood, with their corresponding |
| 32 |
hour differences from Greenwich Mean Time: |
| 33 |
.sp .5 |
| 34 |
.nf |
| 35 |
Standard time: |
| 36 |
YST PST MST CST EST GMT |
| 37 |
9 8 7 6 5 0 |
| 38 |
| 39 |
CET EET AST GST IST JST NZST |
| 40 |
greg |
1.6 |
\-1 \-2 \-3 \-4 \-5.5 \-9 \-12 |
| 41 |
greg |
1.1 |
| 42 |
Daylight savings time: |
| 43 |
YDT PDT MDT CDT EDT BST |
| 44 |
greg |
1.6 |
8 7 6 5 4 \-1 |
| 45 |
greg |
1.1 |
| 46 |
CEST EEST ADT GDT IDT JDT NZDT |
| 47 |
greg |
1.6 |
\-2 \-3 \-4 \-5 \-6.5 \-10 \-13 |
| 48 |
greg |
1.1 |
.fi |
| 49 |
.PP |
| 50 |
If the time is preceded by a plus sign ('+'), then it is interpreted |
| 51 |
as local solar time instead. |
| 52 |
It is very important to specify the correct latitude and longitude |
| 53 |
(unless local solar time is given) using the |
| 54 |
.I \-a |
| 55 |
and |
| 56 |
.I \-o |
| 57 |
options to get the correct solar angles. |
| 58 |
.PP |
| 59 |
The second form gives the solar angles explicitly. |
| 60 |
The altitude is measured in degrees above the horizon, and the |
| 61 |
azimuth is measured in degrees west of South. |
| 62 |
.PP |
| 63 |
The third form prints the default option values. |
| 64 |
.PP |
| 65 |
The output sky distribution is given as a brightness function, |
| 66 |
.I skyfunc. |
| 67 |
Its value is in watts/steradian/meter2. |
| 68 |
The x axis points east, |
| 69 |
the y axis points north, and the z axis corresponds to the zenith. |
| 70 |
The actual material and surface(s) used for the sky is left |
| 71 |
up to the user. |
| 72 |
For a hemispherical blue sky, the description might be: |
| 73 |
.sp |
| 74 |
.nf |
| 75 |
!gensky 4 1 14 |
| 76 |
| 77 |
skyfunc glow skyglow |
| 78 |
0 |
| 79 |
0 |
| 80 |
greg |
1.2 |
4 .99 .99 1.1 0 |
| 81 |
greg |
1.1 |
| 82 |
skyglow source sky |
| 83 |
0 |
| 84 |
0 |
| 85 |
4 0 0 1 180 |
| 86 |
.fi |
| 87 |
.sp |
| 88 |
Often, |
| 89 |
.I skyfunc |
| 90 |
will actually be used to characterize the light coming in from |
| 91 |
a window. |
| 92 |
.PP |
| 93 |
In addition to the specification of |
| 94 |
a sky distribution function, |
| 95 |
.I gensky |
| 96 |
suggests an ambient value in a comment at the beginning of the |
| 97 |
description to use with the |
| 98 |
.I \-av |
| 99 |
option of the RADIANCE rendering programs. |
| 100 |
greg |
1.4 |
(See rvu(1) and rpict(1).) |
| 101 |
greg |
1.1 |
This value is the cosine-weighted radiance of the sky in |
| 102 |
| 103 |
.PP |
| 104 |
.I Gensky |
| 105 |
supports the following options. |
| 106 |
.TP 10n |
| 107 |
greg |
1.7 |
.BR \-y \ year |
| 108 |
If the year is specified, a more accurate solar position algorithm |
| 109 |
[Michalsky 1988] will be used in place of the formula in the IES |
| 110 |
Lighting Handbook. |
| 111 |
.TP |
| 112 |
greg |
1.1 |
.BR \-s |
| 113 |
Sunny sky without sun. |
| 114 |
The sky distribution will correspond to a standard CIE clear day. |
| 115 |
.TP |
| 116 |
.BR \+s |
| 117 |
Sunny sky with sun. |
| 118 |
In addition to the sky distribution function, a source |
| 119 |
description of the sun is generated. |
| 120 |
.TP |
| 121 |
.BR \-c |
| 122 |
Cloudy sky. |
| 123 |
The sky distribution will correspond to a standard CIE overcast day. |
| 124 |
.TP |
| 125 |
.BR \-i |
| 126 |
Intermediate sky without sun. |
| 127 |
The sky will correspond to a standard CIE intermediate day. |
| 128 |
.TP |
| 129 |
.BR \+i |
| 130 |
Intermediate sky with sun. |
| 131 |
In addition to the sky distribution, a (somewhat subdued) sun |
| 132 |
is generated. |
| 133 |
.TP |
| 134 |
.BR \-u |
| 135 |
Uniform cloudy sky. |
| 136 |
The sky distribution will be completely uniform. |
| 137 |
.TP |
| 138 |
.BI -g \ rfl |
| 139 |
Average ground reflectance is |
| 140 |
.I rfl. |
| 141 |
This value is used to compute |
| 142 |
.I skyfunc |
| 143 |
when Dz is negative. |
| 144 |
Ground plane brightness is the same for |
| 145 |
.I \-s |
| 146 |
as for |
| 147 |
.I \+s. |
| 148 |
(Likewise for |
| 149 |
.I \-i |
| 150 |
and |
| 151 |
.I \+i, |
| 152 |
but see the |
| 153 |
.I \-r |
| 154 |
option below.) |
| 155 |
.TP |
| 156 |
.BI -b \ brt |
| 157 |
The zenith brightness is |
| 158 |
.I brt. |
| 159 |
Zenith radiance (in watts/steradian/meter2) is normally computed |
| 160 |
from the sun angle and sky turbidity (for sunny sky). |
| 161 |
It can be given directly instead, using this option. |
| 162 |
.TP |
| 163 |
.BI -B \ irrad |
| 164 |
Same as |
| 165 |
.I \-b, |
| 166 |
except zenith brightness is computed from the horizontal |
| 167 |
diffuse irradiance (in watts/meter2). |
| 168 |
.TP |
| 169 |
.BI -r \ rad |
| 170 |
The solar radiance is |
| 171 |
.I rad. |
| 172 |
Solar radiance (in watts/steradian/meter2) is normally computed from |
| 173 |
the solar altitude. |
| 174 |
This option may be used to override the default calculation. |
| 175 |
If a value of zero is given, no sun description is produced, and the |
| 176 |
contribution of direct solar to ground brightness is neglected. |
| 177 |
.TP |
| 178 |
.BI -R \ irrad |
| 179 |
Same as |
| 180 |
.I \-r, |
| 181 |
except solar radiance is computed from the horizontal direct |
| 182 |
| 183 |
.TP |
| 184 |
.BI -t \ trb |
| 185 |
The turbidity factor is |
| 186 |
.I trb. |
| 187 |
Greater turbidity factors |
| 188 |
correspond to greater atmospheric scattering. |
| 189 |
A turbidity factor of 1.0 indicates an ideal clear atmosphere (i.e. |
| 190 |
a completely dark sky). |
| 191 |
Values less than 1.0 are physically impossible. |
| 192 |
.PP |
| 193 |
The following options do not apply when the solar |
| 194 |
altitude and azimuth are given explicitly. |
| 195 |
.TP |
| 196 |
.BI -a \ lat |
| 197 |
The site latitude is |
| 198 |
.I lat |
| 199 |
degrees north. |
| 200 |
(Use negative angle for south latitude.) |
| 201 |
This is used in the calculation of sun angle. |
| 202 |
.TP |
| 203 |
.BI -o \ lon |
| 204 |
The site longitude is |
| 205 |
.I lon |
| 206 |
degrees west. |
| 207 |
(Use negative angle for east longitude.) |
| 208 |
This is used in the calculation of solar time and sun angle. |
| 209 |
Be sure to give the corresponding standard meridian also! |
| 210 |
If solar time is given directly, then this option has no effect. |
| 211 |
.TP |
| 212 |
.BI -m \ mer |
| 213 |
The site standard meridian is |
| 214 |
.I mer |
| 215 |
degrees west of Greenwich. |
| 216 |
(Use negative angle for east.) |
| 217 |
This is used in the calculation of solar time. |
| 218 |
Be sure to give the correct longitude also! |
| 219 |
greg |
1.5 |
If a time zone or solar time is given directly, then this option has no effect. |
| 220 |
greg |
1.1 |
.SH EXAMPLE |
| 221 |
To produce a sunny sky for July 4th at 2:30pm Eastern daylight time at a |
| 222 |
site latitude of 42 degrees, 89 degrees west longitude: |
| 223 |
.IP "" .2i |
| 224 |
greg |
1.6 |
gensky 7 4 14:30EDT +s \-a 42 \-o 89 |
| 225 |
greg |
1.1 |
.PP |
| 226 |
To produce a sunny sky distribution for a specific sun position but |
| 227 |
without the sun description: |
| 228 |
.IP "" .2i |
| 229 |
greg |
1.6 |
gensky \-ang 23 \-40 \-s |
| 230 |
greg |
1.1 |
.SH FILES |
| 231 |
/usr/local/lib/ray/skybright.cal |
| 232 |
.SH AUTHOR |
| 233 |
Greg Ward |
| 234 |
.SH "SEE ALSO" |
| 235 |
greg |
1.4 |
rpict(1), rvu(1), xform(1) |
