root/radiance/ray/doc/man/man1/gensdaymtx.1
Revision: 1.4
Committed: Thu Apr 10 23:30:58 2025 UTC (2 months, 1 week ago) by greg
Changes since 1.3: +5 -2 lines
feat(gensdaymtx,genssky): TW fixed bug in genssky and added absolute calibration
1 .\" RCSid $Id: gensdaymtx.1,v 1.3 2025/03/27 01:26:55 greg Exp $
2 .TH GENSDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gensdaymtx - generate an annual spectral sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gensdaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-h"
11 ][
12 .B "\-d|\-s"
13 ][
14 .B "\-u"
15 ]][
16 .B "\-r deg"
17 ][
18 .B "\-m N"
19 ][
20 .B "\-p Dir"
21 ][
22 .B "\-n N"
23 ][
24 .B "-o{f|d}"
25 ]
26 [
27 .B "tape.wea"
28 or
29 .B "tape.epw"
30 ]
31 .SH DESCRIPTION
32 .I Gensdaymtx
33 takes a weather tape as input and produces a matrix of spectral sky patch
34 values using the precomputed atmospheric scattering model.
35 Unlike the similarly-named
36 .I gendaymtx
37 tool, the Perez sky model is not used.
38 The weather tape is assumed to be in a special form of the .wea file, which contains
39 a short header with the site parameters followed
40 by the month, day, standard time, direct normal and diffuse horizontal
41 illuminance values, total cloud cover, and broadband aerosol optical depth, one time step per line.
42 Alternatively, a standard EPW (EnergyPlus Weather) file may be provided.
43 Such file can be generated by
44 .I epw2wea
45 with the
46 .I \-a
47 flag.
48 Each time step line is used to compute a column in the output matrix,
49 where rows correspond to sky patch positions, starting with 0 for
50 the ground and continuing to 145 for the zenith using the default
51 .I "\-m 1"
52 parameter setting.
53 .PP
54 .I Gensdaymtx
55 uses the OPAC continental average aerosol profile for the Mie scattering calculation.
56 For every distinct AOD value in the weather tape, a new set of the atmospheric parameters
57 is computed and stored in the atmos_data directory in the current directory, which
58 can be changed using the -p flag. This precomputation can be sped up using the
59 .I \-n NThreads
60 option. There is no speedup after NTHREADS=16.
61 .PP
62 Increasing the
63 .I \-m
64 parameter yields a higher resolution
65 sky using the Reinhart patch subdivision.
66 For example, setting
67 .I "\-m 4"
68 yields a sky with 2305 patches plus one patch for the ground.
69 Each matrix entry is in fact 20 values, corresponding to
70 spectra from 380nm to 730nm at 20nm interval (watts/sr/meter^2).
71 Thus, an hourly weather tape for an entire year would
72 yield 8760x20 (175200) values per output line (row).
73 .PP
74 The
75 .I \-g
76 option may be used to specify a ground color.
77 The default value is
78 .I "\-g 0.2"
79 corresponding to a 20% gray.
80 .PP
81 If there is a sun in the description,
82 .I gensdaymtx
83 will include its contribution in the four nearest sky patches,
84 distributing energy according to centroid proximity.
85 The
86 .I \-d
87 option may be used to produce a sun-only matrix, with no sky contributions,
88 and the ground patch also set to zero.
89 Alternatively, the
90 .I \-s
91 option may be used to exclude any direct solar component from the output,
92 with the other sky and ground patches unaffected.
93 .PP
94 The
95 .I \-u
96 option ignores input times when the sun is below the horizon.
97 .PP
98 By default,
99 .I gensdaymtx
100 assumes the positive Y-axis points north such that the first sky patch
101 is in the Y-axis direction on the horizon, the second patch is just
102 west of that, and so on spiraling around to the final patch near the zenith.
103 The
104 .I \-r
105 (or
106 .I \-rz)
107 option rotates the sky the specified number of degrees counter-clockwise
108 about the zenith, i.e., west of north.
109 This is in keeping with the effect of passing the output of
110 .I gensky(1)
111 or
112 .I gendaylit(1)
113 through
114 .I xform(1)
115 using a similar transform.
116 .PP
117 The
118 .I \-of
119 or
120 .I \-od
121 option may be used to specify binary float or double output, respectively.
122 This is much faster to write and to read, and is therefore preferred on
123 systems that support it.
124 (MS Windows is not one of them.)\0
125 The
126 .I \-h
127 option prevents the output of the usual header information.
128 Finally, the
129 .I \-v
130 option will enable verbose reporting, which is mostly useful for
131 finding out how many time steps are actually in the weather tape.
132 .SH EXAMPLES
133 Produce an annual spectral sky matrix without solar direct:
134 .IP "" .2i
135 epw2wea Detroit.epw Detroit.wea -a;
136 gensdaymtx -m 1 -s Detroit.wea > Detroit.mtx
137 .PP
138 Produce an hourly, annual Reinhart sky matrix
139 with 2306 patches including solar contributions
140 and send float output to
141 .I dctimestep(1)
142 to compute a sensor value matrix:
143 .IP "" .2i
144 gensdaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
145 .SH AUTHORS
146 Taoning Wang
147 .SH "SEE ALSO"
148 dctimestep(1), epw2wea(1),
149 genBSDF(1), gendaylit(1), gendaymtx(1), gensky(1), genskyvec(1), genssky(1),
150 pvsum(1), rcollate(1), rcomb(1), rcontrib(1), rfluxmtx(1), rmtxop(1), xform(1)
