root/radiance/ray/doc/man/man1/gensdaymtx.1
Revision: 1.3
Committed: Thu Mar 27 01:26:55 2025 UTC (2 months, 3 weeks ago) by greg
feat(pvsum): Added new pvsum tool for spectral data, similar to dctimestep
1 .\" RCSid $Id: gensdaymtx.1,v 1.2 2024/08/05 17:23:56 greg Exp $
2 .TH GENSDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gensdaymtx - generate an annual spectral sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gensdaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-h"
11 ][
12 .B "\-d|\-s"
13 ][
14 .B "\-u"
15 ]][
16 .B "\-r deg"
17 ][
18 .B "\-m N"
19 ][
20 .B "\-p Dir"
21 ][
22 .B "\-n N"
23 ][
24 .B "-o{f|d}"
25 ]
26 [
27 .B "tape.wea"
28 ]
29 .SH DESCRIPTION
30 .I Gensdaymtx
31 takes a weather tape as input and produces a matrix of spectral sky patch
32 values using the precomputed atmospheric scattering model.
33 Unlike the similarly-named
34 .I gendaymtx
35 tool, the Perez sky model is not used.
36 The weather tape is assumed to be in a special form of the .wea file, which contains
37 a short header with the site parameters followed
38 by the month, day, standard time, direct normal and diffuse horizontal
39 irradiance values, total cloud cover, and broadband aerosol optical depth, one time step per line.
40 Such file can be generated by
41 .I epw2wea
42 with the
43 .I \-a
44 flag.
45 Each time step line is used to compute a column in the output matrix,
46 where rows correspond to sky patch positions, starting with 0 for
47 the ground and continuing to 145 for the zenith using the default
48 .I "\-m 1"
49 parameter setting.
50 .PP
51 .I Gensdaymtx
52 uses the OPAC continental average aerosol profile for the Mie scattering calculation.
53 For every distinct AOD value in the weather tape, a new set of the atmospheric parameters
54 is computed and stored in the atmos_data directory in the current directory, which
55 can be changed using the -p flag. This precomputation can be sped up using the
56 .I \-n NThreads
57 option. There is no speedup after NTHREADS=16.
58 .PP
59 Increasing the
60 .I \-m
61 parameter yields a higher resolution
62 sky using the Reinhart patch subdivision.
63 For example, setting
64 .I "\-m 4"
65 yields a sky with 2305 patches plus one patch for the ground.
66 Each matrix entry is in fact 20 values, corresponding to
67 spectra from 380nm to 730nm at 20nm interval (watts/sr/meter^2).
68 Thus, an hourly weather tape for an entire year would
69 yield 8760x20 (175200) values per output line (row).
70 .PP
71 The
72 .I \-g
73 option may be used to specify a ground color.
74 The default value is
75 .I "\-g 0.2"
76 corresponding to a 20% gray.
77 .PP
78 If there is a sun in the description,
79 .I gensdaymtx
80 will include its contribution in the four nearest sky patches,
81 distributing energy according to centroid proximity.
82 The
83 .I \-d
84 option may be used to produce a sun-only matrix, with no sky contributions,
85 and the ground patch also set to zero.
86 Alternatively, the
87 .I \-s
88 option may be used to exclude any direct solar component from the output,
89 with the other sky and ground patches unaffected.
90 .PP
91 The
92 .I \-u
93 option ignores input times when the sun is below the horizon.
94 .PP
95 By default,
96 .I gensdaymtx
97 assumes the positive Y-axis points north such that the first sky patch
98 is in the Y-axis direction on the horizon, the second patch is just
99 west of that, and so on spiraling around to the final patch near the zenith.
100 The
101 .I \-r
102 (or
103 .I \-rz)
104 option rotates the sky the specified number of degrees counter-clockwise
105 about the zenith, i.e., west of north.
106 This is in keeping with the effect of passing the output of
107 .I gensky(1)
108 or
109 .I gendaylit(1)
110 through
111 .I xform(1)
112 using a similar transform.
113 .PP
114 The
115 .I \-of
116 or
117 .I \-od
118 option may be used to specify binary float or double output, respectively.
119 This is much faster to write and to read, and is therefore preferred on
120 systems that support it.
121 (MS Windows is not one of them.)\0
122 The
123 .I \-h
124 option prevents the output of the usual header information.
125 Finally, the
126 .I \-v
127 option will enable verbose reporting, which is mostly useful for
128 finding out how many time steps are actually in the weather tape.
129 .SH EXAMPLES
130 Produce an annual spectral sky matrix without solar direct:
131 .IP "" .2i
132 epw2wea Detroit.epw Detroit.wea -a;
133 gensdaymtx -m 1 -s Detroit.wea > Detroit.mtx
134 .PP
135 Produce an hourly, annual Reinhart sky matrix
136 with 2306 patches including solar contributions
137 and send float output to
138 .I dctimestep(1)
139 to compute a sensor value matrix:
140 .IP "" .2i
141 gensdaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
142 .SH AUTHORS
143 Taoning Wang
144 .SH "SEE ALSO"
145 dctimestep(1), epw2wea(1),
146 genBSDF(1), gendaylit(1), gendaymtx(1), gensky(1), genskyvec(1), genssky(1),
147 pvsum(1), rcollate(1), rcomb(1), rcontrib(1), rfluxmtx(1), rmtxop(1), xform(1)
