root/radiance/ray/doc/man/man1/gensdaymtx.1
Revision: 1.4
Committed: Thu Apr 10 23:30:58 2025 UTC (4 months ago) by greg
CVS Tags: rad6R0
Changes since 1.3: +5 -2 lines
feat(gensdaymtx,genssky): TW fixed bug in genssky and added absolute calibration
# User Rev Content
1 greg 1.4 .\" RCSid $Id: gensdaymtx.1,v 1.3 2025/03/27 01:26:55 greg Exp $
2 greg 1.1 .TH GENSDAYMTX 1 01/19/13 RADIANCE
3     .SH NAME
4     gensdaymtx - generate an annual spectral sky matrix from a weather tape
5     .SH SYNOPSIS
6     .B gensdaymtx
7     [
8     .B "\-v"
9     ][
10     .B "\-h"
11     ][
12     .B "\-d|\-s"
13     ][
14     .B "\-u"
15     ]][
16     .B "\-r deg"
17     ][
18     .B "\-m N"
19     ][
20     .B "\-p Dir"
21     ][
22     .B "\-n N"
23     ][
24     .B "-o{f|d}"
25     ]
26     [
27     .B "tape.wea"
28 greg 1.4 or
29     .B "tape.epw"
30 greg 1.1 ]
31     .SH DESCRIPTION
32     .I Gensdaymtx
33     takes a weather tape as input and produces a matrix of spectral sky patch
34     values using the precomputed atmospheric scattering model.
35 greg 1.2 Unlike the similarly-named
36     .I gendaymtx
37     tool, the Perez sky model is not used.
38 greg 1.1 The weather tape is assumed to be in a special form of the .wea file, which contains
39     a short header with the site parameters followed
40     by the month, day, standard time, direct normal and diffuse horizontal
41 greg 1.4 illuminance values, total cloud cover, and broadband aerosol optical depth, one time step per line.
42     Alternatively, a standard EPW (EnergyPlus Weather) file may be provided.
43 greg 1.1 Such file can be generated by
44     .I epw2wea
45 greg 1.2 with the
46 greg 1.1 .I \-a
47     flag.
48     Each time step line is used to compute a column in the output matrix,
49     where rows correspond to sky patch positions, starting with 0 for
50     the ground and continuing to 145 for the zenith using the default
51     .I "\-m 1"
52     parameter setting.
53     .PP
54     .I Gensdaymtx
55     uses the OPAC continental average aerosol profile for the Mie scattering calculation.
56     For every distinct AOD value in the weather tape, a new set of the atmospheric parameters
57     is computed and stored in the atmos_data directory in the current directory, which
58     can be changed using the -p flag. This precomputation can be sped up using the
59     .I \-n NThreads
60     option. There is no speedup after NTHREADS=16.
61     .PP
62     Increasing the
63     .I \-m
64     parameter yields a higher resolution
65     sky using the Reinhart patch subdivision.
66     For example, setting
67     .I "\-m 4"
68     yields a sky with 2305 patches plus one patch for the ground.
69     Each matrix entry is in fact 20 values, corresponding to
70     spectra from 380nm to 730nm at 20nm interval (watts/sr/meter^2).
71     Thus, an hourly weather tape for an entire year would
72     yield 8760x20 (175200) values per output line (row).
73     .PP
74     The
75     .I \-g
76     option may be used to specify a ground color.
77     The default value is
78     .I "\-g 0.2"
79     corresponding to a 20% gray.
80     .PP
81     If there is a sun in the description,
82     .I gensdaymtx
83     will include its contribution in the four nearest sky patches,
84     distributing energy according to centroid proximity.
85     The
86     .I \-d
87     option may be used to produce a sun-only matrix, with no sky contributions,
88     and the ground patch also set to zero.
89     Alternatively, the
90     .I \-s
91     option may be used to exclude any direct solar component from the output,
92     with the other sky and ground patches unaffected.
93     .PP
94     The
95     .I \-u
96     option ignores input times when the sun is below the horizon.
97     .PP
98     By default,
99     .I gensdaymtx
100     assumes the positive Y-axis points north such that the first sky patch
101     is in the Y-axis direction on the horizon, the second patch is just
102     west of that, and so on spiraling around to the final patch near the zenith.
103     The
104     .I \-r
105     (or
106     .I \-rz)
107     option rotates the sky the specified number of degrees counter-clockwise
108     about the zenith, i.e., west of north.
109     This is in keeping with the effect of passing the output of
110     .I gensky(1)
111     or
112     .I gendaylit(1)
113     through
114     .I xform(1)
115     using a similar transform.
116     .PP
117     The
118     .I \-of
119     or
120     .I \-od
121     option may be used to specify binary float or double output, respectively.
122     This is much faster to write and to read, and is therefore preferred on
123     systems that support it.
124     (MS Windows is not one of them.)\0
125     The
126     .I \-h
127     option prevents the output of the usual header information.
128     Finally, the
129     .I \-v
130     option will enable verbose reporting, which is mostly useful for
131     finding out how many time steps are actually in the weather tape.
132     .SH EXAMPLES
133     Produce an annual spectral sky matrix without solar direct:
134     .IP "" .2i
135     epw2wea Detroit.epw Detroit.wea -a;
136     gensdaymtx -m 1 -s Detroit.wea > Detroit.mtx
137     .PP
138     Produce an hourly, annual Reinhart sky matrix
139     with 2306 patches including solar contributions
140     and send float output to
141     .I dctimestep(1)
142     to compute a sensor value matrix:
143     .IP "" .2i
144     gensdaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
145     .SH AUTHORS
146 greg 1.2 Taoning Wang
147 greg 1.1 .SH "SEE ALSO"
148 greg 1.2 dctimestep(1), epw2wea(1),
149     genBSDF(1), gendaylit(1), gendaymtx(1), gensky(1), genskyvec(1), genssky(1),
150 greg 1.3 pvsum(1), rcollate(1), rcomb(1), rcontrib(1), rfluxmtx(1), rmtxop(1), xform(1)
