1 |
.\" RCSid "$Id: genrev.1,v 1.2 2003/12/09 15:59:06 greg Exp $" |
2 |
.TH GENREV 1 11/15/93 RADIANCE |
3 |
.SH NAME |
4 |
genrev - generate a RADIANCE description of surface of revolution |
5 |
.SH SYNOPSIS |
6 |
.B "genrev mat name 'z(t)' 'r(t)' nseg" |
7 |
8 |
.B "\-e expr" |
9 |
10 |
.B "\-f file" |
11 |
12 |
.B \-s |
13 |
14 |
.SH DESCRIPTION |
15 |
.I Genrev |
16 |
produces a RADIANCE scene description of a |
17 |
surface of revolution. |
18 |
The object will be composed of |
19 |
.I nseg |
20 |
cones, cups, cylinders, tubes or rings |
21 |
following the parametric curve defined by |
22 |
.I z(t) |
23 |
(height) |
24 |
and |
25 |
.I r(t) |
26 |
(radius). |
27 |
When |
28 |
.I z |
29 |
is increasing with t, the surface normal points outward. |
30 |
When |
31 |
.I z |
32 |
is decreasing, the normal points inward. |
33 |
The variable |
34 |
.I t |
35 |
used in the function expressions varies |
36 |
from 0 to 1 in even steps of |
37 |
.I 1/nseg. |
38 |
The expressions are of the same type used in RADIANCE |
39 |
function files. |
40 |
Auxiliary expressions and/or files may be specified |
41 |
in any number of |
42 |
.I \-e |
43 |
and |
44 |
.I \-f |
45 |
options. |
46 |
The |
47 |
.I \-s |
48 |
option smooths the surfaces using Phong normal interpolation. |
49 |
.SH EXAMPLE |
50 |
To generate a torus with an inner radius of 1 and an outer radius |
51 |
of 3: |
52 |
.IP "" .2i |
53 |
genrev steel torus 'sin(2*PI*t)' '1+cos(2*PI*t)' 32 |
54 |
.SH AUTHOR |
55 |
Greg Ward |
56 |
.SH BUGS |
57 |
The -s option doesn't modify the surface normal correctly |
58 |
for the opposite side. |
59 |
.SH "SEE ALSO" |
60 |
genbox(1), gensurf(1), genworm(1), icalc(1), rpict(1), rvu(1), xform(1) |
