--- ray/doc/man/man1/genrev.1 2004/01/01 19:31:44 1.3 +++ ray/doc/man/man1/genrev.1 2018/05/04 23:56:49 1.7 @@ -1,4 +1,4 @@ -.\" RCSid "$Id: genrev.1,v 1.3 2004/01/01 19:31:44 greg Exp $" +.\" RCSid "$Id: genrev.1,v 1.7 2018/05/04 23:56:49 greg Exp $" .TH GENREV 1 11/15/93 RADIANCE .SH NAME genrev - generate a RADIANCE description of surface of revolution @@ -43,6 +43,9 @@ in any number of and .I \-f options. +The variable and function definitions in each +.I \-f source +file are read and compiled from the RADIANCE library where it is found. The .I \-s option smooths the surfaces using Phong normal interpolation. @@ -50,11 +53,11 @@ option smooths the surfaces using Phong normal interpo To generate a torus with an inner radius of 1 and an outer radius of 3: .IP "" .2i -genrev steel torus 'sin(2*PI*t)' '1+cos(2*PI*t)' 32 +genrev steel torus 'sin(2*PI*t)' '2+cos(2*PI*t)' 32 +.SH ENVIRONMENT +RAYPATH the directories to check for auxiliary files. .SH AUTHOR Greg Ward -.SH BUGS -The -s option doesn't modify the surface normal correctly -for the opposite side. .SH "SEE ALSO" -genbox(1), gensurf(1), genworm(1), icalc(1), rpict(1), rvu(1), xform(1) +genbox(1), gencat(1), genprism(1), gensurf(1), +genworm(1), rcalc(1), rpict(1), rvu(1), xform(1)
