root/radiance/ray/doc/man/man1/genklemsamp.1
Revision: 1.5
Committed: Thu Jun 14 22:42:21 2012 UTC (13 years ago) by greg
CVS Tags: rad5R4, rad5R2, rad4R2P2, rad5R0, rad5R1, rad4R2, rad4R2P1, rad5R3, HEAD
Changes since 1.4: +6 -6 lines
# User Rev Content
1 greg 1.5 .\" RCSid $Id: genklemsamp.1,v 1.4 2010/09/03 23:53:49 greg Exp $
2 greg 1.1 .TH GENKLEMSAMP 1 6/13/09 RADIANCE
3     .SH NAME
4     genklemsamp - generate ray samples over surfaces using Klems BSDF basis
5     .SH SYNOPSIS
6     .B genklemsamp
7     [
8     .B "\-c N"
9     ][
10     .B "\-f{a|f|d}"
11     ]
12     [
13     .B "view opts"
14     ]
15     [
16     .B "geom.rad .."
17     ]
18     .SH DESCRIPTION
19     .I Genklemsamp
20     generates ray origins and directions to sample planar surfaces
21     needed to determine incident radiances or daylight coefficients.
22     This command is typically used in conjunction with
23 greg 1.5 .I rcontrib(1)
24 greg 1.1 to analyze exterior daylight coefficients
25     for an annual simulation.
26     .PP
27     The view options are needed to specify (at minimum) the view direction,
28     which corresponds to the orientation of the surfaces, and the view up
29     vector, which corresponds to the azimuth=90-degree position on the Klems
30     sampling hemisphere.
31 greg 1.2 The view fore clipping distance is also quite useful, as it provides
32     a means to pass through some thickness in a fenestration system before
33     samples are sent out.
34     Other view options such as the view type and aft
35     clipping distance are overridden or ignored.
36 greg 1.1 .PP
37     If no Radiance scene files are provided, then the specified parallel
38     view defines the width, height, center, and orientation of the window
39     or facade of interest.
40     If one or more scene files are given, they
41     are presumed to contain planar surfaces over which
42     .I genklemsamp
43     will originate samples.
44     The sampled surface normals must correspond to the specified
45     view direction, and unaligned surfaces are silently ignored.
46     .PP
47     The
48     .I \-c
49     option specifies the number of rays to sample per Klems direction.
50     These samples will be distributed evenly over the surface(s).
51     The default setting is 1000.
52     .PP
53     The
54     .I \-ff
55     option specifies that output rays should be generated as 32-bit IEEE binary
56     float values.
57     This may be more efficient if passed directly to
58 greg 1.5 .I rcontrib
59 greg 1.1 or
60     .I rtrace(1)
61     with the same option.
62     Likewise, the
63     .I \-fd
64     option specifies 64-bit IEEE binary double values.
65     The default setting of
66     .I \-fa
67     produces ASCII floating point values.
68     .SH EXAMPLE
69     To generate 500 samples per direction over a set of south-facing windows and
70     pass to
71 greg 1.5 .I rcontrib
72 greg 1.1 to compute daylight coefficients in a matrix:
73     .IP "" .2i
74     genklemsamp -c 500 -vd 0 -1 0 -vu 0 0 1 south_windows.rad
75 greg 1.5 | rcontrib -c 500 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins exterior.oct > Dsouth.dat
76 greg 1.1 .SH AUTHOR
77     Greg Ward
78     .SH "SEE ALSO"
79 greg 1.4 dctimestep(1), genBSDF(1), genskyvec(1), mkillum(1),
80 greg 1.5 rcontrib(1), rtrace(1), vwrays(1)
