1 |
.\" RCSid $Id$ |
2 |
.TH GENKLEMSAMP 1 6/13/09 RADIANCE |
3 |
.SH NAME |
4 |
genklemsamp - generate ray samples over surfaces using Klems BSDF basis |
5 |
.SH SYNOPSIS |
6 |
.B genklemsamp |
7 |
8 |
.B "\-c N" |
9 |
10 |
.B "\-f{a|f|d}" |
11 |
12 |
13 |
.B "view opts" |
14 |
15 |
16 |
.B "geom.rad .." |
17 |
18 |
.SH DESCRIPTION |
19 |
.I Genklemsamp |
20 |
generates ray origins and directions to sample planar surfaces |
21 |
needed to determine incident radiances or daylight coefficients. |
22 |
This command is typically used in conjunction with |
23 |
.I rtcontrib(1) |
24 |
to analyze exterior daylight coefficients |
25 |
for an annual simulation. |
26 |
.PP |
27 |
The view options are needed to specify (at minimum) the view direction, |
28 |
which corresponds to the orientation of the surfaces, and the view up |
29 |
vector, which corresponds to the azimuth=90-degree position on the Klems |
30 |
sampling hemisphere. |
31 |
.PP |
32 |
If no Radiance scene files are provided, then the specified parallel |
33 |
view defines the width, height, center, and orientation of the window |
34 |
or facade of interest. |
35 |
If one or more scene files are given, they |
36 |
are presumed to contain planar surfaces over which |
37 |
.I genklemsamp |
38 |
will originate samples. |
39 |
The sampled surface normals must correspond to the specified |
40 |
view direction, and unaligned surfaces are silently ignored. |
41 |
.PP |
42 |
The |
43 |
.I \-c |
44 |
option specifies the number of rays to sample per Klems direction. |
45 |
These samples will be distributed evenly over the surface(s). |
46 |
The default setting is 1000. |
47 |
.PP |
48 |
The |
49 |
.I \-ff |
50 |
option specifies that output rays should be generated as 32-bit IEEE binary |
51 |
float values. |
52 |
This may be more efficient if passed directly to |
53 |
.I rtcontrib |
54 |
or |
55 |
.I rtrace(1) |
56 |
with the same option. |
57 |
Likewise, the |
58 |
.I \-fd |
59 |
option specifies 64-bit IEEE binary double values. |
60 |
The default setting of |
61 |
.I \-fa |
62 |
produces ASCII floating point values. |
63 |
.SH EXAMPLE |
64 |
To generate 500 samples per direction over a set of south-facing windows and |
65 |
pass to |
66 |
.I rtcontrib |
67 |
to compute daylight coefficients in a matrix: |
68 |
.IP "" .2i |
69 |
genklemsamp -c 500 -vd 0 -1 0 -vu 0 0 1 south_windows.rad |
70 |
| rtcontrib -c 500 -f tregenza.cal -b tbin -bn 146 exterior.oct > Dsouth.dat |
71 |
.SH AUTHOR |
72 |
Greg Ward |
73 |
.SH "SEE ALSO" |
74 |
mkillum(1), rtcontrib(1), rtrace(1), vwrays(1) |
