--- ray/doc/man/man1/genklemsamp.1 2009/12/10 00:17:19 1.3 +++ ray/doc/man/man1/genklemsamp.1 2012/06/14 22:42:21 1.5 @@ -1,4 +1,4 @@ -.\" RCSid $Id: genklemsamp.1,v 1.3 2009/12/10 00:17:19 greg Exp $ +.\" RCSid $Id: genklemsamp.1,v 1.5 2012/06/14 22:42:21 greg Exp $ .TH GENKLEMSAMP 1 6/13/09 RADIANCE .SH NAME genklemsamp - generate ray samples over surfaces using Klems BSDF basis @@ -20,7 +20,7 @@ genklemsamp - generate ray samples over surfaces using generates ray origins and directions to sample planar surfaces needed to determine incident radiances or daylight coefficients. This command is typically used in conjunction with -.I rtcontrib(1) +.I rcontrib(1) to analyze exterior daylight coefficients for an annual simulation. .PP @@ -55,7 +55,7 @@ The option specifies that output rays should be generated as 32-bit IEEE binary float values. This may be more efficient if passed directly to -.I rtcontrib +.I rcontrib or .I rtrace(1) with the same option. @@ -68,12 +68,13 @@ produces ASCII floating point values. .SH EXAMPLE To generate 500 samples per direction over a set of south-facing windows and pass to -.I rtcontrib +.I rcontrib to compute daylight coefficients in a matrix: .IP "" .2i genklemsamp -c 500 -vd 0 -1 0 -vu 0 0 1 south_windows.rad -| rtcontrib -c 500 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins exterior.oct > Dsouth.dat +| rcontrib -c 500 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins exterior.oct > Dsouth.dat .SH AUTHOR Greg Ward .SH "SEE ALSO" -dctimestep(1), genskyvec(1), mkillum(1), rtcontrib(1), rtrace(1), vwrays(1) +dctimestep(1), genBSDF(1), genskyvec(1), mkillum(1), +rcontrib(1), rtrace(1), vwrays(1)
