| 1 |
.\" RCSid $Id$
| 2 |
.TH GENKLEMSAMP 1 6/13/09 RADIANCE
| 3 |
.SH NAME
| 4 |
genklemsamp - generate ray samples over surfaces using Klems BSDF basis
| 5 |
.SH SYNOPSIS
| 6 |
.B genklemsamp
| 7 |
| 8 |
.B "\-c N"
| 9 |
| 10 |
.B "\-f{a|f|d}"
| 11 |
| 12 |
| 13 |
.B "view opts"
| 14 |
| 15 |
| 16 |
.B "geom.rad .."
| 17 |
| 18 |
.SH DESCRIPTION
| 19 |
.I Genklemsamp
| 20 |
generates ray origins and directions to sample planar surfaces
| 21 |
needed to determine incident radiances or daylight coefficients.
| 22 |
This command is typically used in conjunction with
| 23 |
.I rtcontrib(1)
| 24 |
to analyze exterior daylight coefficients
| 25 |
for an annual simulation.
| 26 |
.PP
| 27 |
The view options are needed to specify (at minimum) the view direction,
| 28 |
which corresponds to the orientation of the surfaces, and the view up
| 29 |
vector, which corresponds to the azimuth=90-degree position on the Klems
| 30 |
sampling hemisphere.
| 31 |
.PP
| 32 |
If no Radiance scene files are provided, then the specified parallel
| 33 |
view defines the width, height, center, and orientation of the window
| 34 |
or facade of interest.
| 35 |
If one or more scene files are given, they
| 36 |
are presumed to contain planar surfaces over which
| 37 |
.I genklemsamp
| 38 |
will originate samples.
| 39 |
The sampled surface normals must correspond to the specified
| 40 |
view direction, and unaligned surfaces are silently ignored.
| 41 |
.PP
| 42 |
The
| 43 |
.I \-c
| 44 |
option specifies the number of rays to sample per Klems direction.
| 45 |
These samples will be distributed evenly over the surface(s).
| 46 |
The default setting is 1000.
| 47 |
.PP
| 48 |
The
| 49 |
.I \-ff
| 50 |
option specifies that output rays should be generated as 32-bit IEEE binary
| 51 |
float values.
| 52 |
This may be more efficient if passed directly to
| 53 |
.I rtcontrib
| 54 |
or
| 55 |
.I rtrace(1)
| 56 |
with the same option.
| 57 |
Likewise, the
| 58 |
.I \-fd
| 59 |
option specifies 64-bit IEEE binary double values.
| 60 |
The default setting of
| 61 |
.I \-fa
| 62 |
produces ASCII floating point values.
| 63 |
.SH EXAMPLE
| 64 |
To generate 500 samples per direction over a set of south-facing windows and
| 65 |
pass to
| 66 |
.I rtcontrib
| 67 |
to compute daylight coefficients in a matrix:
| 68 |
.IP "" .2i
| 69 |
genklemsamp -c 500 -vd 0 -1 0 -vu 0 0 1 south_windows.rad
| 70 |
| rtcontrib -c 500 -f tregenza.cal -b tbin -bn 146 exterior.oct > Dsouth.dat
| 71 |
.SH AUTHOR
| 72 |
Greg Ward
| 73 |
.SH "SEE ALSO"
| 74 |
mkillum(1), rtcontrib(1), rtrace(1), vwrays(1)
