root/Development/ray/doc/man/man1/genklemsamp.1
Revision: 1.5
Committed: Thu Jun 14 22:42:21 2012 UTC (13 years, 4 months ago) by greg
CVS Tags: rad6R0, rad5R4, rad5R3, rad5R2, rad5R1, rad5R0, rad4R2P2, rad4R2P1, rad4R2, HEAD
Changes since 1.4: +6 -6 lines
1 .\" RCSid $Id: genklemsamp.1,v 1.4 2010/09/03 23:53:49 greg Exp $
2 .TH GENKLEMSAMP 1 6/13/09 RADIANCE
3 .SH NAME
4 genklemsamp - generate ray samples over surfaces using Klems BSDF basis
5 .SH SYNOPSIS
6 .B genklemsamp
7 [
8 .B "\-c N"
9 ][
10 .B "\-f{a|f|d}"
11 ]
12 [
13 .B "view opts"
14 ]
15 [
16 .B "geom.rad .."
17 ]
18 .SH DESCRIPTION
19 .I Genklemsamp
20 generates ray origins and directions to sample planar surfaces
21 needed to determine incident radiances or daylight coefficients.
22 This command is typically used in conjunction with
23 .I rcontrib(1)
24 to analyze exterior daylight coefficients
25 for an annual simulation.
26 .PP
27 The view options are needed to specify (at minimum) the view direction,
28 which corresponds to the orientation of the surfaces, and the view up
29 vector, which corresponds to the azimuth=90-degree position on the Klems
30 sampling hemisphere.
31 The view fore clipping distance is also quite useful, as it provides
32 a means to pass through some thickness in a fenestration system before
33 samples are sent out.
34 Other view options such as the view type and aft
35 clipping distance are overridden or ignored.
36 .PP
37 If no Radiance scene files are provided, then the specified parallel
38 view defines the width, height, center, and orientation of the window
39 or facade of interest.
40 If one or more scene files are given, they
41 are presumed to contain planar surfaces over which
42 .I genklemsamp
43 will originate samples.
44 The sampled surface normals must correspond to the specified
45 view direction, and unaligned surfaces are silently ignored.
46 .PP
47 The
48 .I \-c
49 option specifies the number of rays to sample per Klems direction.
50 These samples will be distributed evenly over the surface(s).
51 The default setting is 1000.
52 .PP
53 The
54 .I \-ff
55 option specifies that output rays should be generated as 32-bit IEEE binary
56 float values.
57 This may be more efficient if passed directly to
58 .I rcontrib
59 or
60 .I rtrace(1)
61 with the same option.
62 Likewise, the
63 .I \-fd
64 option specifies 64-bit IEEE binary double values.
65 The default setting of
66 .I \-fa
67 produces ASCII floating point values.
68 .SH EXAMPLE
69 To generate 500 samples per direction over a set of south-facing windows and
70 pass to
71 .I rcontrib
72 to compute daylight coefficients in a matrix:
73 .IP "" .2i
74 genklemsamp -c 500 -vd 0 -1 0 -vu 0 0 1 south_windows.rad
75 | rcontrib -c 500 -e MF:1 -f reinhart.cal -b rbin -bn Nrbins exterior.oct > Dsouth.dat
76 .SH AUTHOR
77 Greg Ward
78 .SH "SEE ALSO"
79 dctimestep(1), genBSDF(1), genskyvec(1), mkillum(1),
80 rcontrib(1), rtrace(1), vwrays(1)
