root/radiance/ray/doc/man/man1/gendaymtx.1
Revision: 1.19
Committed: Wed Feb 26 20:39:28 2025 UTC (3 months, 3 weeks ago) by greg
Changes since 1.18: +7 -2 lines
feat(gendaymtx): Added ability to read dew point from EPW input data
1 .\" RCSid $Id: gendaymtx.1,v 1.18 2024/08/05 17:23:56 greg Exp $
2 .TH GENDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gendaymtx - generate an annual Perez sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gendaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-h"
11 ][
12 .B "\-A"
13 ][
14 .B "\-d|\-s|\-n"
15 ][
16 .B "\-u"
17 ][
18 .B "\-D sunfile"
19 [
20 .B "\-M sunmods"
21 ]][
22 .B "\-r deg"
23 ][
24 .B "\-m N"
25 ][
26 .B "\-g r g b"
27 ][
28 .B "\-c r g b"
29 ][
30 .B "-o{f|d}"
31 ][
32 .B "\-O{0|1}"
33 ][
34 .B "\-i intvl"
35 ]
36 [
37 .B "tape.wea"
38 or
39 .B "tape.epw"
40 ]
41 .SH DESCRIPTION
42 .I Gendaymtx
43 takes a weather tape as input and produces a matrix of sky patch
44 values using the Perez all-weather model.
45 The weather tape may be in the simple ASCII format understood
46 by DAYSIM, which contains a short header with the site parameters followed
47 by the month, day, standard time, direct normal and diffuse horizontal
48 irradiance values, one time step per line.
49 Alternatively, a standard EPW (Energy Plus Weather) input may be provided,
50 in which case additional information such as the dew point temperature may
51 be used in the calculation.
52 Each time step line is used to compute a column in the output matrix,
53 where rows correspond to sky patch positions, starting with 0 for
54 the ground and continuing to 145 for the zenith using the default
55 .I "\-m 1"
56 parameter setting.
57 .PP
58 Increasing the
59 .I \-m
60 parameter yields a higher resolution
61 sky using the Reinhart patch subdivision.
62 For example, setting
63 .I "\-m 4"
64 yields a sky with 2305 patches plus one patch for the ground.
65 Each matrix entry is in fact three values, corresponding to
66 red green and blue radiance channels (watts/sr/meter^2).
67 Thus, an hourly weather tape for an entire year would
68 yield 8760x3 (26280) values per output line (row).
69 .PP
70 The
71 .I \-A
72 option tells
73 .I gendaymtx
74 to generate a single column corresponding to an average sky
75 computed over all the input time steps, rather than one
76 column per time step.
77 .PP
78 The
79 .I \-c
80 option may be used to specify a color for the sky.
81 The gray value should equal 1 for proper energy balance.
82 The default sky color is
83 .I "\-c 0.960 1.004 1.118".
84 Similarly, the
85 .I \-g
86 option may be used to specify a ground color.
87 The default value is
88 .I "\-g 0.2 0.2 0.2"
89 corresponding to a 20% gray.
90 .PP
91 If there is a sun in the description,
92 .I gendaymtx
93 will include its contribution in the four nearest sky patches,
94 distributing energy according to centroid proximity.
95 The
96 .I \-d
97 option may be used to produce a sun-only matrix, with no sky contributions,
98 and the ground patch also set to zero.
99 Alternatively, the
100 .I \-s
101 option may be used to exclude any direct solar component from the output,
102 with the other sky and ground patches unaffected.
103 .PP
104 The
105 .I \-u
106 option ignores input times when the sun is below the horizon.
107 This is a convenient way to average daylight hours only with the
108 .I \-A
109 option or to ensure that matrix entries correspond to solar positions
110 produced with the
111 .I \-D
112 option, described below.
113 .PP
114 The
115 .I \-n
116 option may be used if no matrix output is desired at all.
117 This may be used to merely check the input, or in combination with the
118 .I \-D
119 option, below.
120 .PP
121 The
122 .I \-D
123 option may be used to specify an output file to contain a list of
124 solar positions and intensities corresponding to time steps in the
125 weather tape where the sun has any portion above the horizon.
126 Sun radiance values may be zero if the direct amount is zero on the input.
127 Sun modifiers and names will be indexed by the minute, numbered from
128 midnight, January 1st.
129 If a hyphen ('-') is given as the argument to
130 .I \-D,
131 then the sun descriptions will be directed to the standard output.
132 This implies the
133 .I \-n
134 option just described.
135 If the
136 .I \-M
137 option is given as well, it will be used to record the modifier
138 names used in the
139 .I \-D
140 output, for convenient input to
141 .I rcontrib(1)
142 and
143 .I rfluxmtx(1).
144 .PP
145 By default,
146 .I gendaymtx
147 assumes the positive Y-axis points north such that the first sky patch
148 is in the Y-axis direction on the horizon, the second patch is just
149 west of that, and so on spiraling around to the final patch near the zenith.
150 The
151 .I \-r
152 (or
153 .I \-rz)
154 option rotates the sky the specified number of degrees counter-clockwise
155 about the zenith, i.e., west of north.
156 This is in keeping with the effect of passing the output of
157 .I gensky(1)
158 or
159 .I gendaylit(1)
160 through
161 .I xform(1)
162 using a similar transform.
163 .PP
164 The
165 .I \-i
166 option specifies the actual capture interval in minutes of the original
167 weather data.
168 Please see the man page for
169 .I gendaylit
170 to understand this correction, which is applied only near sunrise and
171 sunset.
172 .PP
173 The
174 .I \-of
175 or
176 .I \-od
177 option may be used to specify binary float or double output, respectively.
178 This is much faster to write and to read, and is therefore preferred on
179 systems that support it.
180 (MS Windows is not one of them.)\0
181 The
182 .I \-O1
183 option specifies that output should be total solar radiance rather
184 than visible radiance.
185 The
186 .I \-h
187 option prevents the output of the usual header information.
188 Finally, the
189 .I \-v
190 option will enable verbose reporting, which is mostly useful for
191 finding out how many time steps are actually in the weather tape.
192 .SH EXAMPLES
193 Produce an uncolored Tregenza sky matrix without solar direct:
194 .IP "" .2i
195 gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx
196 .PP
197 Produce an hourly, annual Reinhart sky matrix
198 with 2306 patches including solar contributions
199 and send float output to
200 .I dctimestep(1)
201 to compute a sensor value matrix:
202 .IP "" .2i
203 gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
204 .SH AUTHORS
205 Ian Ashdown wrote most of the code,
206 based on Jean-Jacques Delaunay's original gendaylit(1) implementation.
207 Greg Ward wrote the final parameter parsing and weather tape conversion.
208 .SH "SEE ALSO"
209 dctimestep(1), genBSDF(1), gendaylit(1), gensdaymtx(1), gensky(1),
210 genskyvec(1), genssky(1),
211 rcollate(1), rcontrib(1), rfluxmtx(1), rmtxop(1), xform(1)
