1 |
.\" RCSid $Id: gendaymtx.1,v 1.16 2022/08/13 17:24:56 greg Exp $ |
2 |
.TH GENDAYMTX 1 01/19/13 RADIANCE |
3 |
.SH NAME |
4 |
gendaymtx - generate an annual Perez sky matrix from a weather tape |
5 |
.SH SYNOPSIS |
6 |
.B gendaymtx |
7 |
8 |
.B "\-v" |
9 |
10 |
.B "\-h" |
11 |
12 |
.B "\-A" |
13 |
14 |
.B "\-d|\-s|\-n" |
15 |
16 |
.B "\-u" |
17 |
18 |
.B "\-D sunfile" |
19 |
20 |
.B "\-M sunmods" |
21 |
22 |
.B "\-r deg" |
23 |
24 |
.B "\-m N" |
25 |
26 |
.B "\-g r g b" |
27 |
28 |
.B "\-c r g b" |
29 |
30 |
.B "-o{f|d}" |
31 |
32 |
.B "\-O{0|1}" |
33 |
34 |
.B "\-i intvl" |
35 |
36 |
37 |
.B "tape.wea" |
38 |
39 |
.SH DESCRIPTION |
40 |
.I Gendaymtx |
41 |
takes a weather tape as input and produces a matrix of sky patch |
42 |
values using the Perez all-weather model. |
43 |
The weather tape is assumed to be in the simple ASCII format understood |
44 |
by DAYSIM, which contains a short header with the site parameters followed |
45 |
by the month, day, standard time, direct normal and diffuse horizontal |
46 |
irradiance values, one time step per line. |
47 |
Each time step line is used to compute a column in the output matrix, |
48 |
where rows correspond to sky patch positions, starting with 0 for |
49 |
the ground and continuing to 145 for the zenith using the default |
50 |
.I "\-m 1" |
51 |
parameter setting. |
52 |
.PP |
53 |
Increasing the |
54 |
.I \-m |
55 |
parameter yields a higher resolution |
56 |
sky using the Reinhart patch subdivision. |
57 |
For example, setting |
58 |
.I "\-m 4" |
59 |
yields a sky with 2305 patches plus one patch for the ground. |
60 |
Each matrix entry is in fact three values, corresponding to |
61 |
red green and blue radiance channels (watts/sr/meter^2). |
62 |
Thus, an hourly weather tape for an entire year would |
63 |
yield 8760x3 (26280) values per output line (row). |
64 |
.PP |
65 |
The |
66 |
.I \-A |
67 |
option tells |
68 |
.I gendaymtx |
69 |
to generate a single column corresponding to an average sky |
70 |
computed over all the input time steps, rather than one |
71 |
column per time step. |
72 |
.PP |
73 |
The |
74 |
.I \-c |
75 |
option may be used to specify a color for the sky. |
76 |
The gray value should equal 1 for proper energy balance. |
77 |
The default sky color is |
78 |
.I "\-c 0.960 1.004 1.118". |
79 |
Similarly, the |
80 |
.I \-g |
81 |
option may be used to specify a ground color. |
82 |
The default value is |
83 |
.I "\-g 0.2 0.2 0.2" |
84 |
corresponding to a 20% gray. |
85 |
.PP |
86 |
If there is a sun in the description, |
87 |
.I gendaymtx |
88 |
will include its contribution in the four nearest sky patches, |
89 |
distributing energy according to centroid proximity. |
90 |
The |
91 |
.I \-d |
92 |
option may be used to produce a sun-only matrix, with no sky contributions, |
93 |
and the ground patch also set to zero. |
94 |
Alternatively, the |
95 |
.I \-s |
96 |
option may be used to exclude any direct solar component from the output, |
97 |
with the other sky and ground patches unaffected. |
98 |
.PP |
99 |
The |
100 |
.I \-u |
101 |
option ignores input times when the sun is below the horizon. |
102 |
This is a convenient way to average daylight hours only with the |
103 |
.I \-A |
104 |
option or to ensure that matrix entries correspond to solar positions |
105 |
produced with the |
106 |
.I \-D |
107 |
option, described below. |
108 |
.PP |
109 |
The |
110 |
.I \-n |
111 |
option may be used if no matrix output is desired at all. |
112 |
This may be used to merely check the input, or in combination with the |
113 |
.I \-D |
114 |
option, below. |
115 |
.PP |
116 |
The |
117 |
.I \-D |
118 |
option may be used to specify an output file to contain a list of |
119 |
solar positions and intensities corresponding to time steps in the |
120 |
weather tape where the sun has any portion above the horizon. |
121 |
Sun radiance values may be zero if the direct amount is zero on the input. |
122 |
Sun modifiers and names will be indexed by the minute, numbered from |
123 |
midnight, January 1st. |
124 |
If a hyphen ('-') is given as the argument to |
125 |
.I \-D, |
126 |
then the sun descriptions will be directed to the standard output. |
127 |
This implies the |
128 |
.I \-n |
129 |
option just described. |
130 |
If the |
131 |
.I \-M |
132 |
option is given as well, it will be used to record the modifier |
133 |
names used in the |
134 |
.I \-D |
135 |
output, for convenient input to |
136 |
.I rcontrib(1) |
137 |
and |
138 |
.I rfluxmtx(1). |
139 |
.PP |
140 |
By default, |
141 |
.I gendaymtx |
142 |
assumes the positive Y-axis points north such that the first sky patch |
143 |
is in the Y-axis direction on the horizon, the second patch is just |
144 |
west of that, and so on spiraling around to the final patch near the zenith. |
145 |
The |
146 |
.I \-r |
147 |
(or |
148 |
.I \-rz) |
149 |
option rotates the sky the specified number of degrees counter-clockwise |
150 |
about the zenith, i.e., west of north. |
151 |
This is in keeping with the effect of passing the output of |
152 |
.I gensky(1) |
153 |
or |
154 |
.I gendaylit(1) |
155 |
through |
156 |
.I xform(1) |
157 |
using a similar transform. |
158 |
.PP |
159 |
The |
160 |
.I \-i |
161 |
option specifies the actual capture interval in minutes of the original |
162 |
weather data. |
163 |
Please see the man page for |
164 |
.I gendaylit |
165 |
to understand this correction, which is applied only near sunrise and |
166 |
sunset. |
167 |
.PP |
168 |
The |
169 |
.I \-of |
170 |
or |
171 |
.I \-od |
172 |
option may be used to specify binary float or double output, respectively. |
173 |
This is much faster to write and to read, and is therefore preferred on |
174 |
systems that support it. |
175 |
(MS Windows is not one of them.)\0 |
176 |
The |
177 |
.I \-O1 |
178 |
option specifies that output should be total solar radiance rather |
179 |
than visible radiance. |
180 |
The |
181 |
.I \-h |
182 |
option prevents the output of the usual header information. |
183 |
Finally, the |
184 |
.I \-v |
185 |
option will enable verbose reporting, which is mostly useful for |
186 |
finding out how many time steps are actually in the weather tape. |
187 |
.SH EXAMPLES |
188 |
Produce an uncolored Tregenza sky matrix without solar direct: |
189 |
.IP "" .2i |
190 |
gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx |
191 |
.PP |
192 |
Produce an hourly, annual Reinhart sky matrix |
193 |
with 2306 patches including solar contributions |
194 |
and send float output to |
195 |
.I dctimestep(1) |
196 |
to compute a sensor value matrix: |
197 |
.IP "" .2i |
198 |
gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat |
199 |
.SH AUTHORS |
200 |
Ian Ashdown wrote most of the code, |
201 |
based on Jean-Jacques Delaunay's original gendaylit(1) implementation. |
202 |
Greg Ward wrote the final parameter parsing and weather tape conversion. |
203 |
.SH "SEE ALSO" |
204 |
dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), |
205 |
rcollate(1), rcontrib(1), rfluxmtx(1), xform(1) |
