--- ray/doc/man/man1/gendaymtx.1 2013/01/20 02:07:16 1.1 +++ ray/doc/man/man1/gendaymtx.1 2019/05/28 15:19:17 1.9 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.1 2013/01/20 02:07:16 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.9 2019/05/28 15:19:17 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -7,8 +7,12 @@ gendaymtx - generate an annual Perez sky matrix from a [ .B "\-v" ][ +.B "\-h" +][ .B "\-d|\-s" ][ +.B "\-r deg" +][ .B "\-m N" ][ .B "\-g r g b" @@ -16,6 +20,8 @@ gendaymtx - generate an annual Perez sky matrix from a .B "\-c r g b" ][ .B "-o{f|d}" +][ +.B "-O{0|1}" ] [ .B "tape.wea" @@ -49,7 +55,7 @@ yield 8760x3 (26280) values per output line (row). The .I \-c option may be used to specify a color for the sky. -The gray value should equal 1 for proper energy balance +The gray value should equal 1 for proper energy balance. The default sky color is .I "\-c 0.960 1.004 1.118". Similarly, the @@ -61,12 +67,37 @@ corresponding to a 20% gray. .PP The .I \-d -option may be used to produce a sun-only matrix, with no sky contributions. +option may be used to produce a sun-only matrix, with no sky contributions, +and the ground patch also set to zero. Alternatively, the .I \-s -option may be used to exclude any direct solar component from the output. +option may be used to exclude any direct solar component from the output, +with the rest of the sky and ground patch unaffected. +If there is a sun in the description, +.I gendaymtx +will include its contribution in the four nearest sky patches, +distributing energy according to centroid proximity. .PP +By default, +.I gendaymtx +assumes the positive Y-axis points north such that the first sky patch +is in the Y-axis direction on the horizon, the second patch is just +west of that, and so on spiraling around to the final patch near the zenith. The +.I \-r +(or +.I \-rz) +option rotates the sky the specified number of degrees counter-clockwise +about the zenith, i.e., west of north. +This is in keeping with the effect of passing the output of +.I gensky(1) +or +.I gendaylit(1) +through +.I xform(1) +using a similar transform. +.PP +The .I \-of or .I \-od @@ -74,6 +105,13 @@ option may be used to specify binary float or double o This is much faster to write and to read, and is therefore preferred on systems that support it. (MS Windows is not one of them.)\0 +The +.I \-O1 +option specifies that output should be total solar radiance rather +than visible radiance. +The +.I \-h +option prevents the output of the usual header information. Finally, the .I \-v option will enable verbose reporting, which is mostly useful for @@ -95,4 +133,5 @@ Ian Ashdown wrote most of the code, based on Jean-Jacques Delaunay's original gendaylit(1) implementation. Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" -dctimestep(1), genBSDF(1), gendaylit(1), genskyvec(1), rcontrib(1) +dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), +rcollate(1), rcontrib(1), xform(1)
