--- ray/doc/man/man1/gendaymtx.1 2018/05/24 15:21:15 1.8 +++ ray/doc/man/man1/gendaymtx.1 2022/08/13 17:24:56 1.16 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.8 2018/05/24 15:21:15 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.16 2022/08/13 17:24:56 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -9,8 +9,16 @@ gendaymtx - generate an annual Perez sky matrix from a ][ .B "\-h" ][ -.B "\-d|\-s" +.B "\-A" ][ +.B "\-d|\-s|\-n" +][ +.B "\-u" +][ +.B "\-D sunfile" +[ +.B "\-M sunmods" +]][ .B "\-r deg" ][ .B "\-m N" @@ -42,7 +50,7 @@ parameter setting. .PP Increasing the .I \-m -parameter, typically by factors of two, yields a higher resolution +parameter yields a higher resolution sky using the Reinhart patch subdivision. For example, setting .I "\-m 4" @@ -53,6 +61,14 @@ Thus, an hourly weather tape for an entire year would yield 8760x3 (26280) values per output line (row). .PP The +.I \-A +option tells +.I gendaymtx +to generate a single column corresponding to an average sky +computed over all the input time steps, rather than one +column per time step. +.PP +The .I \-c option may be used to specify a color for the sky. The gray value should equal 1 for proper energy balance. @@ -65,17 +81,60 @@ The default value is .I "\-g 0.2 0.2 0.2" corresponding to a 20% gray. .PP -The -.I \-d -option may be used to produce a sun-only matrix, with no sky contributions. -Alternatively, the -.I \-s -option may be used to exclude any direct solar component from the output. If there is a sun in the description, .I gendaymtx will include its contribution in the four nearest sky patches, distributing energy according to centroid proximity. +The +.I \-d +option may be used to produce a sun-only matrix, with no sky contributions, +and the ground patch also set to zero. +Alternatively, the +.I \-s +option may be used to exclude any direct solar component from the output, +with the other sky and ground patches unaffected. .PP +The +.I \-u +option ignores input times when the sun is below the horizon. +This is a convenient way to average daylight hours only with the +.I \-A +option or to ensure that matrix entries correspond to solar positions +produced with the +.I \-D +option, described below. +.PP +The +.I \-n +option may be used if no matrix output is desired at all. +This may be used to merely check the input, or in combination with the +.I \-D +option, below. +.PP +The +.I \-D +option may be used to specify an output file to contain a list of +solar positions and intensities corresponding to time steps in the +weather tape where the sun has any portion above the horizon. +Sun radiance values may be zero if the direct amount is zero on the input. +Sun modifiers and names will be indexed by the minute, numbered from +midnight, January 1st. +If a hyphen ('-') is given as the argument to +.I \-D, +then the sun descriptions will be directed to the standard output. +This implies the +.I \-n +option just described. +If the +.I \-M +option is given as well, it will be used to record the modifier +names used in the +.I \-D +output, for convenient input to +.I rcontrib(1) +and +.I rfluxmtx(1). +.PP By default, .I gendaymtx assumes the positive Y-axis points north such that the first sky patch @@ -132,4 +191,4 @@ based on Jean-Jacques Delaunay's original gendaylit(1) Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), -rcollate(1), rcontrib(1), xform(1) +rcollate(1), rcontrib(1), rfluxmtx(1), xform(1)
