--- ray/doc/man/man1/gendaymtx.1 2013/02/05 19:31:40 1.3 +++ ray/doc/man/man1/gendaymtx.1 2014/05/30 00:00:54 1.6 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.3 2013/02/05 19:31:40 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.6 2014/05/30 00:00:54 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -7,6 +7,8 @@ gendaymtx - generate an annual Perez sky matrix from a [ .B "\-v" ][ +.B "\-h" +][ .B "\-d|\-s" ][ .B "\-r deg" @@ -18,6 +20,8 @@ gendaymtx - generate an annual Perez sky matrix from a .B "\-c r g b" ][ .B "-o{f|d}" +][ +.B "-O{0|1}" ] [ .B "tape.wea" @@ -95,6 +99,13 @@ option may be used to specify binary float or double o This is much faster to write and to read, and is therefore preferred on systems that support it. (MS Windows is not one of them.)\0 +The +.I \-O1 +option specifies that output should be total solar radiance rather +than visible radiance. +The +.I \-h +option prevents the output of the usual header information. Finally, the .I \-v option will enable verbose reporting, which is mostly useful for @@ -116,5 +127,5 @@ Ian Ashdown wrote most of the code, based on Jean-Jacques Delaunay's original gendaylit(1) implementation. Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" -dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), rcontrib(1), -xform(1) +dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), +rcollate(1), rcontrib(1), xform(1)
