--- ray/doc/man/man1/gendaymtx.1 2013/02/05 06:00:19 1.2 +++ ray/doc/man/man1/gendaymtx.1 2013/09/05 17:53:22 1.5 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.2 2013/02/05 06:00:19 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.5 2013/09/05 17:53:22 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -18,6 +18,8 @@ gendaymtx - generate an annual Perez sky matrix from a .B "\-c r g b" ][ .B "-o{f|d}" +][ +.B "-O{0|1}" ] [ .B "tape.wea" @@ -68,12 +70,17 @@ Alternatively, the .I \-s option may be used to exclude any direct solar component from the output. .PP +By default, +.I gendaymtx +assumes the positive Y-axis points north such that the first sky patch +is in the Y-axis direction on the horizon, the second patch is just +west of that, and so on spiraling around to the final patch near the zenith. The .I \-r (or .I \-rz) option rotates the sky the specified number of degrees counter-clockwise -about the zenith, i.e., east of South. +about the zenith, i.e., west of north. This is in keeping with the effect of passing the output of .I gensky(1) or @@ -90,6 +97,10 @@ option may be used to specify binary float or double o This is much faster to write and to read, and is therefore preferred on systems that support it. (MS Windows is not one of them.)\0 +The +.I \-O1 +option specifies that output should be total solar radiance rather +than visible radiance. Finally, the .I \-v option will enable verbose reporting, which is mostly useful for @@ -111,5 +122,5 @@ Ian Ashdown wrote most of the code, based on Jean-Jacques Delaunay's original gendaylit(1) implementation. Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" -dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), rcontrib(1), -xform(1) +dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), +rcollate(1), rcontrib(1), xform(1)
