--- ray/doc/man/man1/gendaymtx.1 2013/09/05 17:53:22 1.5 +++ ray/doc/man/man1/gendaymtx.1 2019/06/25 00:09:45 1.10 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.5 2013/09/05 17:53:22 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.10 2019/06/25 00:09:45 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -7,6 +7,10 @@ gendaymtx - generate an annual Perez sky matrix from a [ .B "\-v" ][ +.B "\-h" +][ +.B "\-A" +][ .B "\-d|\-s" ][ .B "\-r deg" @@ -51,9 +55,17 @@ Thus, an hourly weather tape for an entire year would yield 8760x3 (26280) values per output line (row). .PP The +.I \-A +option tells +.I gendaymtx +to generate a single column corresponding to an average sky +computed over all the input time steps, rather than one +column per time step. +.PP +The .I \-c option may be used to specify a color for the sky. -The gray value should equal 1 for proper energy balance +The gray value should equal 1 for proper energy balance. The default sky color is .I "\-c 0.960 1.004 1.118". Similarly, the @@ -65,10 +77,16 @@ corresponding to a 20% gray. .PP The .I \-d -option may be used to produce a sun-only matrix, with no sky contributions. +option may be used to produce a sun-only matrix, with no sky contributions, +and the ground patch also set to zero. Alternatively, the .I \-s -option may be used to exclude any direct solar component from the output. +option may be used to exclude any direct solar component from the output, +with the rest of the sky and ground patch unaffected. +If there is a sun in the description, +.I gendaymtx +will include its contribution in the four nearest sky patches, +distributing energy according to centroid proximity. .PP By default, .I gendaymtx @@ -101,6 +119,9 @@ The .I \-O1 option specifies that output should be total solar radiance rather than visible radiance. +The +.I \-h +option prevents the output of the usual header information. Finally, the .I \-v option will enable verbose reporting, which is mostly useful for
