--- ray/doc/man/man1/gendaymtx.1 2019/06/25 00:09:45 1.10 +++ ray/doc/man/man1/gendaymtx.1 2024/04/26 23:10:59 1.17 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.10 2019/06/25 00:09:45 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.17 2024/04/26 23:10:59 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -11,8 +11,14 @@ gendaymtx - generate an annual Perez sky matrix from a ][ .B "\-A" ][ -.B "\-d|\-s" +.B "\-d|\-s|\-n" ][ +.B "\-u" +][ +.B "\-D sunfile" +[ +.B "\-M sunmods" +]][ .B "\-r deg" ][ .B "\-m N" @@ -23,7 +29,9 @@ gendaymtx - generate an annual Perez sky matrix from a ][ .B "-o{f|d}" ][ -.B "-O{0|1}" +.B "\-O{0|1}" +][ +.B "\-i intvl" ] [ .B "tape.wea" @@ -44,7 +52,7 @@ parameter setting. .PP Increasing the .I \-m -parameter, typically by factors of two, yields a higher resolution +parameter yields a higher resolution sky using the Reinhart patch subdivision. For example, setting .I "\-m 4" @@ -75,6 +83,10 @@ The default value is .I "\-g 0.2 0.2 0.2" corresponding to a 20% gray. .PP +If there is a sun in the description, +.I gendaymtx +will include its contribution in the four nearest sky patches, +distributing energy according to centroid proximity. The .I \-d option may be used to produce a sun-only matrix, with no sky contributions, @@ -82,12 +94,49 @@ and the ground patch also set to zero. Alternatively, the .I \-s option may be used to exclude any direct solar component from the output, -with the rest of the sky and ground patch unaffected. -If there is a sun in the description, -.I gendaymtx -will include its contribution in the four nearest sky patches, -distributing energy according to centroid proximity. +with the other sky and ground patches unaffected. .PP +The +.I \-u +option ignores input times when the sun is below the horizon. +This is a convenient way to average daylight hours only with the +.I \-A +option or to ensure that matrix entries correspond to solar positions +produced with the +.I \-D +option, described below. +.PP +The +.I \-n +option may be used if no matrix output is desired at all. +This may be used to merely check the input, or in combination with the +.I \-D +option, below. +.PP +The +.I \-D +option may be used to specify an output file to contain a list of +solar positions and intensities corresponding to time steps in the +weather tape where the sun has any portion above the horizon. +Sun radiance values may be zero if the direct amount is zero on the input. +Sun modifiers and names will be indexed by the minute, numbered from +midnight, January 1st. +If a hyphen ('-') is given as the argument to +.I \-D, +then the sun descriptions will be directed to the standard output. +This implies the +.I \-n +option just described. +If the +.I \-M +option is given as well, it will be used to record the modifier +names used in the +.I \-D +output, for convenient input to +.I rcontrib(1) +and +.I rfluxmtx(1). +.PP By default, .I gendaymtx assumes the positive Y-axis points north such that the first sky patch @@ -108,6 +157,15 @@ through using a similar transform. .PP The +.I \-i +option specifies the actual capture interval in minutes of the original +weather data. +Please see the man page for +.I gendaylit +to understand this correction, which is applied only near sunrise and +sunset. +.PP +The .I \-of or .I \-od @@ -144,4 +202,4 @@ based on Jean-Jacques Delaunay's original gendaylit(1) Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), -rcollate(1), rcontrib(1), xform(1) +rcollate(1), rcontrib(1), rfluxmtx(1), xform(1)
