--- ray/doc/man/man1/gendaymtx.1 2019/06/25 00:09:45 1.10 +++ ray/doc/man/man1/gendaymtx.1 2020/04/13 17:12:19 1.12 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.10 2019/06/25 00:09:45 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.12 2020/04/13 17:12:19 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -11,8 +11,12 @@ gendaymtx - generate an annual Perez sky matrix from a ][ .B "\-A" ][ -.B "\-d|\-s" +.B "\-d|\-s|\-n" ][ +.B "\-D sunfile" +][ +.B "\-M sunmods" +][ .B "\-r deg" ][ .B "\-m N" @@ -44,7 +48,7 @@ parameter setting. .PP Increasing the .I \-m -parameter, typically by factors of two, yields a higher resolution +parameter yields a higher resolution sky using the Reinhart patch subdivision. For example, setting .I "\-m 4" @@ -88,6 +92,37 @@ If there is a sun in the description, will include its contribution in the four nearest sky patches, distributing energy according to centroid proximity. .PP +The +.I \-n +option may be used if no matrix output is desired. +This may be used to merely check the input, or in combination with the +.I \-D +option, below. +.PP +The +.I \-D +option may be used to specify an output file to contain a list of +solar positions and intensities corresponding to time steps in the +weather tape where the sun has any portion above the horizion. +Sun radiance values may be zero if the direct amount is zero on the input. +Sun modifiers and names will be indexed by the minute, numbered from +midnight, January 1st. +If a hyphen ('-') is given as the argument to +.I \-D, +then the sun descriptions will be directed to the standard output. +This implies the +.I \-n +option just described. +If the +.I \-M +option is given as well, it will be used to record the modifier +names used in the +.I \-D +output, for convenient input to +.I rcontrib(1) +and +.I rfluxmtx(1). +.PP By default, .I gendaymtx assumes the positive Y-axis points north such that the first sky patch @@ -144,4 +179,4 @@ based on Jean-Jacques Delaunay's original gendaylit(1) Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), -rcollate(1), rcontrib(1), xform(1) +rcollate(1), rcontrib(1), rfluxmtx(1), xform(1)
