--- ray/doc/man/man1/gendaymtx.1 2013/01/20 02:07:16 1.1 +++ ray/doc/man/man1/gendaymtx.1 2013/02/05 06:00:19 1.2 @@ -1,4 +1,4 @@ -.\" RCSid $Id: gendaymtx.1,v 1.1 2013/01/20 02:07:16 greg Exp $ +.\" RCSid $Id: gendaymtx.1,v 1.2 2013/02/05 06:00:19 greg Exp $ .TH GENDAYMTX 1 01/19/13 RADIANCE .SH NAME gendaymtx - generate an annual Perez sky matrix from a weather tape @@ -9,6 +9,8 @@ gendaymtx - generate an annual Perez sky matrix from a ][ .B "\-d|\-s" ][ +.B "\-r deg" +][ .B "\-m N" ][ .B "\-g r g b" @@ -67,6 +69,20 @@ Alternatively, the option may be used to exclude any direct solar component from the output. .PP The +.I \-r +(or +.I \-rz) +option rotates the sky the specified number of degrees counter-clockwise +about the zenith, i.e., east of South. +This is in keeping with the effect of passing the output of +.I gensky(1) +or +.I gendaylit(1) +through +.I xform(1) +using a similar transform. +.PP +The .I \-of or .I \-od @@ -95,4 +111,5 @@ Ian Ashdown wrote most of the code, based on Jean-Jacques Delaunay's original gendaylit(1) implementation. Greg Ward wrote the final parameter parsing and weather tape conversion. .SH "SEE ALSO" -dctimestep(1), genBSDF(1), gendaylit(1), genskyvec(1), rcontrib(1) +dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), rcontrib(1), +xform(1)
