root/radiance/ray/doc/man/man1/gendaymtx.1
Revision: 1.4
Committed: Tue Apr 30 17:05:27 2013 UTC (12 years, 1 month ago) by greg
Changes since 1.3: +7 -1 lines
Added -O1 option to output total solar radiance
1 .\" RCSid $Id: gendaymtx.1,v 1.3 2013/02/05 19:31:40 greg Exp $
2 .TH GENDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gendaymtx - generate an annual Perez sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gendaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-d|\-s"
11 ][
12 .B "\-r deg"
13 ][
14 .B "\-m N"
15 ][
16 .B "\-g r g b"
17 ][
18 .B "\-c r g b"
19 ][
20 .B "-o{f|d}"
21 ][
22 .B "-O{0|1}"
23 ]
24 [
25 .B "tape.wea"
26 ]
27 .SH DESCRIPTION
28 .I Gendaymtx
29 takes a weather tape as input and produces a matrix of sky patch
30 values using the Perez all-weather model.
31 The weather tape is assumed to be in the simple ASCII format understood
32 by DAYSIM, which contains a short header with the site parameters followed
33 by the month, day, standard time, direct normal and diffuse horizontal
34 irradiance values, one time step per line.
35 Each time step line is used to compute a column in the output matrix,
36 where rows correspond to sky patch positions, starting with 0 for
37 the ground and continuing to 145 for the zenith using the default
38 .I "\-m 1"
39 parameter setting.
40 .PP
41 Increasing the
42 .I \-m
43 parameter, typically by factors of two, yields a higher resolution
44 sky using the Reinhart patch subdivision.
45 For example, setting
46 .I "\-m 4"
47 yields a sky with 2305 patches plus one patch for the ground.
48 Each matrix entry is in fact three values, corresponding to
49 red green and blue radiance channels (watts/sr/meter^2).
50 Thus, an hourly weather tape for an entire year would
51 yield 8760x3 (26280) values per output line (row).
52 .PP
53 The
54 .I \-c
55 option may be used to specify a color for the sky.
56 The gray value should equal 1 for proper energy balance
57 The default sky color is
58 .I "\-c 0.960 1.004 1.118".
59 Similarly, the
60 .I \-g
61 option may be used to specify a ground color.
62 The default value is
63 .I "\-g 0.2 0.2 0.2"
64 corresponding to a 20% gray.
65 .PP
66 The
67 .I \-d
68 option may be used to produce a sun-only matrix, with no sky contributions.
69 Alternatively, the
70 .I \-s
71 option may be used to exclude any direct solar component from the output.
72 .PP
73 By default,
74 .I gendaymtx
75 assumes the positive Y-axis points north such that the first sky patch
76 is in the Y-axis direction on the horizon, the second patch is just
77 west of that, and so on spiraling around to the final patch near the zenith.
78 The
79 .I \-r
80 (or
81 .I \-rz)
82 option rotates the sky the specified number of degrees counter-clockwise
83 about the zenith, i.e., west of north.
84 This is in keeping with the effect of passing the output of
85 .I gensky(1)
86 or
87 .I gendaylit(1)
88 through
89 .I xform(1)
90 using a similar transform.
91 .PP
92 The
93 .I \-of
94 or
95 .I \-od
96 option may be used to specify binary float or double output, respectively.
97 This is much faster to write and to read, and is therefore preferred on
98 systems that support it.
99 (MS Windows is not one of them.)\0
100 The
101 .I \-O1
102 option specifies that output should be total solar radiance rather
103 than visible radiance.
104 Finally, the
105 .I \-v
106 option will enable verbose reporting, which is mostly useful for
107 finding out how many time steps are actually in the weather tape.
108 .SH EXAMPLES
109 Produce an uncolored Tregenza sky matrix without solar direct:
110 .IP "" .2i
111 gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx
112 .PP
113 Produce an hourly, annual Reinhart sky matrix
114 with 2306 patches including solar contributions
115 and send float output to
116 .I dctimestep(1)
117 to compute a sensor value matrix:
118 .IP "" .2i
119 gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
120 .SH AUTHORS
121 Ian Ashdown wrote most of the code,
122 based on Jean-Jacques Delaunay's original gendaylit(1) implementation.
123 Greg Ward wrote the final parameter parsing and weather tape conversion.
124 .SH "SEE ALSO"
125 dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), rcontrib(1),
126 xform(1)
