root/Development/ray/doc/man/man1/gendaymtx.1
Revision: 1.9
Committed: Tue May 28 15:19:17 2019 UTC (6 years, 4 months ago) by greg
Clarified wording as recommended by Lars.
1 .\" RCSid $Id: gendaymtx.1,v 1.8 2018/05/24 15:21:15 greg Exp $
2 .TH GENDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gendaymtx - generate an annual Perez sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gendaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-h"
11 ][
12 .B "\-d|\-s"
13 ][
14 .B "\-r deg"
15 ][
16 .B "\-m N"
17 ][
18 .B "\-g r g b"
19 ][
20 .B "\-c r g b"
21 ][
22 .B "-o{f|d}"
23 ][
24 .B "-O{0|1}"
25 ]
26 [
27 .B "tape.wea"
28 ]
29 .SH DESCRIPTION
30 .I Gendaymtx
31 takes a weather tape as input and produces a matrix of sky patch
32 values using the Perez all-weather model.
33 The weather tape is assumed to be in the simple ASCII format understood
34 by DAYSIM, which contains a short header with the site parameters followed
35 by the month, day, standard time, direct normal and diffuse horizontal
36 irradiance values, one time step per line.
37 Each time step line is used to compute a column in the output matrix,
38 where rows correspond to sky patch positions, starting with 0 for
39 the ground and continuing to 145 for the zenith using the default
40 .I "\-m 1"
41 parameter setting.
42 .PP
43 Increasing the
44 .I \-m
45 parameter, typically by factors of two, yields a higher resolution
46 sky using the Reinhart patch subdivision.
47 For example, setting
48 .I "\-m 4"
49 yields a sky with 2305 patches plus one patch for the ground.
50 Each matrix entry is in fact three values, corresponding to
51 red green and blue radiance channels (watts/sr/meter^2).
52 Thus, an hourly weather tape for an entire year would
53 yield 8760x3 (26280) values per output line (row).
54 .PP
55 The
56 .I \-c
57 option may be used to specify a color for the sky.
58 The gray value should equal 1 for proper energy balance.
59 The default sky color is
60 .I "\-c 0.960 1.004 1.118".
61 Similarly, the
62 .I \-g
63 option may be used to specify a ground color.
64 The default value is
65 .I "\-g 0.2 0.2 0.2"
66 corresponding to a 20% gray.
67 .PP
68 The
69 .I \-d
70 option may be used to produce a sun-only matrix, with no sky contributions,
71 and the ground patch also set to zero.
72 Alternatively, the
73 .I \-s
74 option may be used to exclude any direct solar component from the output,
75 with the rest of the sky and ground patch unaffected.
76 If there is a sun in the description,
77 .I gendaymtx
78 will include its contribution in the four nearest sky patches,
79 distributing energy according to centroid proximity.
80 .PP
81 By default,
82 .I gendaymtx
83 assumes the positive Y-axis points north such that the first sky patch
84 is in the Y-axis direction on the horizon, the second patch is just
85 west of that, and so on spiraling around to the final patch near the zenith.
86 The
87 .I \-r
88 (or
89 .I \-rz)
90 option rotates the sky the specified number of degrees counter-clockwise
91 about the zenith, i.e., west of north.
92 This is in keeping with the effect of passing the output of
93 .I gensky(1)
94 or
95 .I gendaylit(1)
96 through
97 .I xform(1)
98 using a similar transform.
99 .PP
100 The
101 .I \-of
102 or
103 .I \-od
104 option may be used to specify binary float or double output, respectively.
105 This is much faster to write and to read, and is therefore preferred on
106 systems that support it.
107 (MS Windows is not one of them.)\0
108 The
109 .I \-O1
110 option specifies that output should be total solar radiance rather
111 than visible radiance.
112 The
113 .I \-h
114 option prevents the output of the usual header information.
115 Finally, the
116 .I \-v
117 option will enable verbose reporting, which is mostly useful for
118 finding out how many time steps are actually in the weather tape.
119 .SH EXAMPLES
120 Produce an uncolored Tregenza sky matrix without solar direct:
121 .IP "" .2i
122 gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx
123 .PP
124 Produce an hourly, annual Reinhart sky matrix
125 with 2306 patches including solar contributions
126 and send float output to
127 .I dctimestep(1)
128 to compute a sensor value matrix:
129 .IP "" .2i
130 gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
131 .SH AUTHORS
132 Ian Ashdown wrote most of the code,
133 based on Jean-Jacques Delaunay's original gendaylit(1) implementation.
134 Greg Ward wrote the final parameter parsing and weather tape conversion.
135 .SH "SEE ALSO"
136 dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1),
137 rcollate(1), rcontrib(1), xform(1)
