root/Development/ray/doc/man/man1/gendaymtx.1
Revision: 1.15
Committed: Wed Feb 17 02:30:08 2021 UTC (4 years, 7 months ago) by greg
Changes since 1.14: +2 -2 lines
docs: typo
1 .\" RCSid $Id: gendaymtx.1,v 1.14 2020/09/11 16:53:57 greg Exp $
2 .TH GENDAYMTX 1 01/19/13 RADIANCE
3 .SH NAME
4 gendaymtx - generate an annual Perez sky matrix from a weather tape
5 .SH SYNOPSIS
6 .B gendaymtx
7 [
8 .B "\-v"
9 ][
10 .B "\-h"
11 ][
12 .B "\-A"
13 ][
14 .B "\-d|\-s|\-n"
15 ][
16 .B "\-u"
17 ][
18 .B "\-D sunfile"
19 [
20 .B "\-M sunmods"
21 ]][
22 .B "\-r deg"
23 ][
24 .B "\-m N"
25 ][
26 .B "\-g r g b"
27 ][
28 .B "\-c r g b"
29 ][
30 .B "-o{f|d}"
31 ][
32 .B "-O{0|1}"
33 ]
34 [
35 .B "tape.wea"
36 ]
37 .SH DESCRIPTION
38 .I Gendaymtx
39 takes a weather tape as input and produces a matrix of sky patch
40 values using the Perez all-weather model.
41 The weather tape is assumed to be in the simple ASCII format understood
42 by DAYSIM, which contains a short header with the site parameters followed
43 by the month, day, standard time, direct normal and diffuse horizontal
44 irradiance values, one time step per line.
45 Each time step line is used to compute a column in the output matrix,
46 where rows correspond to sky patch positions, starting with 0 for
47 the ground and continuing to 145 for the zenith using the default
48 .I "\-m 1"
49 parameter setting.
50 .PP
51 Increasing the
52 .I \-m
53 parameter yields a higher resolution
54 sky using the Reinhart patch subdivision.
55 For example, setting
56 .I "\-m 4"
57 yields a sky with 2305 patches plus one patch for the ground.
58 Each matrix entry is in fact three values, corresponding to
59 red green and blue radiance channels (watts/sr/meter^2).
60 Thus, an hourly weather tape for an entire year would
61 yield 8760x3 (26280) values per output line (row).
62 .PP
63 The
64 .I \-A
65 option tells
66 .I gendaymtx
67 to generate a single column corresponding to an average sky
68 computed over all the input time steps, rather than one
69 column per time step.
70 .PP
71 The
72 .I \-c
73 option may be used to specify a color for the sky.
74 The gray value should equal 1 for proper energy balance.
75 The default sky color is
76 .I "\-c 0.960 1.004 1.118".
77 Similarly, the
78 .I \-g
79 option may be used to specify a ground color.
80 The default value is
81 .I "\-g 0.2 0.2 0.2"
82 corresponding to a 20% gray.
83 .PP
84 The
85 .I \-d
86 option may be used to produce a sun-only matrix, with no sky contributions,
87 and the ground patch also set to zero.
88 Alternatively, the
89 .I \-s
90 option may be used to exclude any direct solar component from the output,
91 with the rest of the sky and ground patch unaffected.
92 If there is a sun in the description,
93 .I gendaymtx
94 will include its contribution in the four nearest sky patches,
95 distributing energy according to centroid proximity.
96 .PP
97 The
98 .I \-u
99 option ignores input times when the sun is below the horizon.
100 This is a convenient way to average daylight hours only with the
101 .I \-A
102 option or to ensure that matrix entries correspond to solar positions
103 produced with the
104 .I \-D
105 option, described below.
106 .PP
107 The
108 .I \-n
109 option may be used if no matrix output is desired at all.
110 This may be used to merely check the input, or in combination with the
111 .I \-D
112 option, below.
113 .PP
114 The
115 .I \-D
116 option may be used to specify an output file to contain a list of
117 solar positions and intensities corresponding to time steps in the
118 weather tape where the sun has any portion above the horizon.
119 Sun radiance values may be zero if the direct amount is zero on the input.
120 Sun modifiers and names will be indexed by the minute, numbered from
121 midnight, January 1st.
122 If a hyphen ('-') is given as the argument to
123 .I \-D,
124 then the sun descriptions will be directed to the standard output.
125 This implies the
126 .I \-n
127 option just described.
128 If the
129 .I \-M
130 option is given as well, it will be used to record the modifier
131 names used in the
132 .I \-D
133 output, for convenient input to
134 .I rcontrib(1)
135 and
136 .I rfluxmtx(1).
137 .PP
138 By default,
139 .I gendaymtx
140 assumes the positive Y-axis points north such that the first sky patch
141 is in the Y-axis direction on the horizon, the second patch is just
142 west of that, and so on spiraling around to the final patch near the zenith.
143 The
144 .I \-r
145 (or
146 .I \-rz)
147 option rotates the sky the specified number of degrees counter-clockwise
148 about the zenith, i.e., west of north.
149 This is in keeping with the effect of passing the output of
150 .I gensky(1)
151 or
152 .I gendaylit(1)
153 through
154 .I xform(1)
155 using a similar transform.
156 .PP
157 The
158 .I \-of
159 or
160 .I \-od
161 option may be used to specify binary float or double output, respectively.
162 This is much faster to write and to read, and is therefore preferred on
163 systems that support it.
164 (MS Windows is not one of them.)\0
165 The
166 .I \-O1
167 option specifies that output should be total solar radiance rather
168 than visible radiance.
169 The
170 .I \-h
171 option prevents the output of the usual header information.
172 Finally, the
173 .I \-v
174 option will enable verbose reporting, which is mostly useful for
175 finding out how many time steps are actually in the weather tape.
176 .SH EXAMPLES
177 Produce an uncolored Tregenza sky matrix without solar direct:
178 .IP "" .2i
179 gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx
180 .PP
181 Produce an hourly, annual Reinhart sky matrix
182 with 2306 patches including solar contributions
183 and send float output to
184 .I dctimestep(1)
185 to compute a sensor value matrix:
186 .IP "" .2i
187 gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat
188 .SH AUTHORS
189 Ian Ashdown wrote most of the code,
190 based on Jean-Jacques Delaunay's original gendaylit(1) implementation.
191 Greg Ward wrote the final parameter parsing and weather tape conversion.
192 .SH "SEE ALSO"
193 dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1),
194 rcollate(1), rcontrib(1), rfluxmtx(1), xform(1)
