1 |
.\" RCSid $Id: gendaymtx.1,v 1.8 2018/05/24 15:21:15 greg Exp $ |
2 |
.TH GENDAYMTX 1 01/19/13 RADIANCE |
3 |
.SH NAME |
4 |
gendaymtx - generate an annual Perez sky matrix from a weather tape |
5 |
.SH SYNOPSIS |
6 |
.B gendaymtx |
7 |
8 |
.B "\-v" |
9 |
10 |
.B "\-h" |
11 |
12 |
.B "\-d|\-s" |
13 |
14 |
.B "\-r deg" |
15 |
16 |
.B "\-m N" |
17 |
18 |
.B "\-g r g b" |
19 |
20 |
.B "\-c r g b" |
21 |
22 |
.B "-o{f|d}" |
23 |
24 |
.B "-O{0|1}" |
25 |
26 |
27 |
.B "tape.wea" |
28 |
29 |
.SH DESCRIPTION |
30 |
.I Gendaymtx |
31 |
takes a weather tape as input and produces a matrix of sky patch |
32 |
values using the Perez all-weather model. |
33 |
The weather tape is assumed to be in the simple ASCII format understood |
34 |
by DAYSIM, which contains a short header with the site parameters followed |
35 |
by the month, day, standard time, direct normal and diffuse horizontal |
36 |
irradiance values, one time step per line. |
37 |
Each time step line is used to compute a column in the output matrix, |
38 |
where rows correspond to sky patch positions, starting with 0 for |
39 |
the ground and continuing to 145 for the zenith using the default |
40 |
.I "\-m 1" |
41 |
parameter setting. |
42 |
.PP |
43 |
Increasing the |
44 |
.I \-m |
45 |
parameter, typically by factors of two, yields a higher resolution |
46 |
sky using the Reinhart patch subdivision. |
47 |
For example, setting |
48 |
.I "\-m 4" |
49 |
yields a sky with 2305 patches plus one patch for the ground. |
50 |
Each matrix entry is in fact three values, corresponding to |
51 |
red green and blue radiance channels (watts/sr/meter^2). |
52 |
Thus, an hourly weather tape for an entire year would |
53 |
yield 8760x3 (26280) values per output line (row). |
54 |
.PP |
55 |
The |
56 |
.I \-c |
57 |
option may be used to specify a color for the sky. |
58 |
The gray value should equal 1 for proper energy balance. |
59 |
The default sky color is |
60 |
.I "\-c 0.960 1.004 1.118". |
61 |
Similarly, the |
62 |
.I \-g |
63 |
option may be used to specify a ground color. |
64 |
The default value is |
65 |
.I "\-g 0.2 0.2 0.2" |
66 |
corresponding to a 20% gray. |
67 |
.PP |
68 |
The |
69 |
.I \-d |
70 |
option may be used to produce a sun-only matrix, with no sky contributions, |
71 |
and the ground patch also set to zero. |
72 |
Alternatively, the |
73 |
.I \-s |
74 |
option may be used to exclude any direct solar component from the output, |
75 |
with the rest of the sky and ground patch unaffected. |
76 |
If there is a sun in the description, |
77 |
.I gendaymtx |
78 |
will include its contribution in the four nearest sky patches, |
79 |
distributing energy according to centroid proximity. |
80 |
.PP |
81 |
By default, |
82 |
.I gendaymtx |
83 |
assumes the positive Y-axis points north such that the first sky patch |
84 |
is in the Y-axis direction on the horizon, the second patch is just |
85 |
west of that, and so on spiraling around to the final patch near the zenith. |
86 |
The |
87 |
.I \-r |
88 |
(or |
89 |
.I \-rz) |
90 |
option rotates the sky the specified number of degrees counter-clockwise |
91 |
about the zenith, i.e., west of north. |
92 |
This is in keeping with the effect of passing the output of |
93 |
.I gensky(1) |
94 |
or |
95 |
.I gendaylit(1) |
96 |
through |
97 |
.I xform(1) |
98 |
using a similar transform. |
99 |
.PP |
100 |
The |
101 |
.I \-of |
102 |
or |
103 |
.I \-od |
104 |
option may be used to specify binary float or double output, respectively. |
105 |
This is much faster to write and to read, and is therefore preferred on |
106 |
systems that support it. |
107 |
(MS Windows is not one of them.)\0 |
108 |
The |
109 |
.I \-O1 |
110 |
option specifies that output should be total solar radiance rather |
111 |
than visible radiance. |
112 |
The |
113 |
.I \-h |
114 |
option prevents the output of the usual header information. |
115 |
Finally, the |
116 |
.I \-v |
117 |
option will enable verbose reporting, which is mostly useful for |
118 |
finding out how many time steps are actually in the weather tape. |
119 |
.SH EXAMPLES |
120 |
Produce an uncolored Tregenza sky matrix without solar direct: |
121 |
.IP "" .2i |
122 |
gendaymtx -m 1 -c 1 1 1 -s Detroit.wea > Detroit.mtx |
123 |
.PP |
124 |
Produce an hourly, annual Reinhart sky matrix |
125 |
with 2306 patches including solar contributions |
126 |
and send float output to |
127 |
.I dctimestep(1) |
128 |
to compute a sensor value matrix: |
129 |
.IP "" .2i |
130 |
gendaymtx -m 4 -of VancouverBC.wea | dctimestep -if -n 8760 DCoef.mtx > res.dat |
131 |
.SH AUTHORS |
132 |
Ian Ashdown wrote most of the code, |
133 |
based on Jean-Jacques Delaunay's original gendaylit(1) implementation. |
134 |
Greg Ward wrote the final parameter parsing and weather tape conversion. |
135 |
.SH "SEE ALSO" |
136 |
dctimestep(1), genBSDF(1), gendaylit(1), gensky(1), genskyvec(1), |
137 |
rcollate(1), rcontrib(1), xform(1) |
